I recently dropped my cpu (5800x3d) and bent a few pins. I tried to straighten them as much as possible buy now my pc can't run 4 slots off ram. I can only run 2 of the 4 slots or else it won't post. I tried to locate any pin still bent but could they all look straight. I am at a loss of what to do. Am I better off getting a new cpu?
https://linustechtips.com/topic/1635528-cpu-pin-issue/
The first picture is good. All the pins are present and straight.
If the cpu pins enter the socket cleanly, then I see no reason for faulty behaviour.
Did you try to reset the bios to have the Ram run at stock frequency (without Expo/XMP) ?
Did you try both sets of Ram, do both work on their own ?
Edited by leclod
If you don't quote us, we won't know you answered
https://linustechtips.com/topic/1635528-cpu-pin-issue/#findComment-16887091
