At first I thought it was GPU 4080 super. Rma the GPU and they found no issue. Stuck my old GPU in (3070) while the rma was off and it still did it. Happens after gaming for about 1hr, but sometimes I can play for 2-3 hrs and it doesn't happen. If I turn pc off for about 30 min it goes away but if I directly restart it's still there.I thought something was getting hot but Temps are good CPU ~70 gpu~ 50. Nothing is hot in HW monitor 64. Asrock z890 wifi (3.21 bios), 32 gigs Corsair vengeance (16x2) xmp @ 7000, 265k running 200s profile standard clocks, gigabyte gaming 4080 super, msi mag 1000w PSU. Voltages look good. Ran occt with no errors. Have reinstalled drivers with DDU.  970 evo m.2 and WD 2tb m.2.  I have taken screen shots to verify it's not cables or monitor and it's in the screen shots.  It's like the shading or shadows turn blue (most of the time) and like 2 times it turned yellow. I would have thought cpu-ram stability but occt ran with no errors. Steam and the games are on a different m.2 than Windows could that cause the corruption? I'm lost on this one.
https://linustechtips.com/topic/1635527-blue-artifacts-not-gpu-need-help/
You say it is in screenshots, if you save them and look at it on a totally different system, is it still there? Alternatively, if you let the system rest and look at screenshots taken when it was happening, does it change back? Or post one of those screenshots here and we can see if there's a difference between that and what I presume are photos.
If it really is the PC output then some software might be changing it. If it was yellow only, maybe some blue light filter function? But that wouldn't explain it going blue.
To be honest I've looked and I can't find the SS. I may have deleted them when I mailed the rma. But I recall being told to take SS to rule out monitor and cables, and I recall doing that.
I just went through and deleted all stored shader cache, also dropped the xmp profile from 7000 to 6800..somewhere something is getting corrupted.if and when it happens again I'll take more SS and transfer them.
