need some advice..
im going to wc my 280x vapor x with a universal Gpu block EK-VGA Supremacy - Acetal+Nickel and ram sinks.. The vrm already has a heatsink over it. so i was planing to ziptie a fan over it.
im not sure what size 70mm, 80mm or 92mm. im looking for the least amount of noise and good airflow? also can i use the fan header on the card instead of my mobo.
Thanks
\\ Case: Phanteks Enthoo Primo // CPU: Intel Core i5 3570K 5GHz // Mobo: Gigabyte GA-Z77 X-UD4H  // CPU BL: EK-Supremacy EVO Acetal // Pump+Top: EK-D5 Vario + X-TOP  // Res: Bitspower Z-Multi 250mm  // Rads: Alphacool NexXxoS Monsta 80mm 480mm + Alphacool NexXxoS XT45 480mm  // GPU: Sapphire R9 280X Vapor-X 3GB GDDR5 OC 1100MHz//1550MHz // GPU BL: Alphacool NexXxos GPXR9280M07 // PSU: Corsair CMPSU-850AXUK // RAM: 16GB 4x4GB Corsair DDR3 Vengeance LP 1600MHz // Tubing: Xspc HighFlex 1/2" ID, 3/4" OD // Fittings: EK-CSQ 13/19mm + EK-AF 45°/90° + Koolance QD3 + Others  // HDDs: 256GB Crucial M4 + 30GB OCZSSD2-1VTX30G  + 8TB Seagate 3.5  // Fan Control: Lamptron Touch 30w x 6 // Fans: Noiseblocker BlackSilent PL2 1400rpm x12 + BitFenix 140mm Spectre PRO 1200rpm x2 // OS: Windows 8.1 X64 // LEDS: Darkside // Mouse: Corsair Vengeance M95 // Keyboards: Corsair Vengeance K95 + Logitech G13 // Monitors: Eizo Forbis FS2333BK x3 \\
https://linustechtips.com/topic/163530-fan-for-vrm-universal-gpu-block/
go with a 92 mm fan, and you can use the fan header on the GPU itself and use afterburner to set a fan curve for it.
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
Just get a waterblock for it, won't be much more.
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
Arctic f9 Pro 23db / 39cfm
http://www.amazon.co.uk/ARTIC-Cooling-F9-PWM/dp/B002QVLBPO
What do you think of this one?
Cant there is not a full block for this card.
that fan will do nicely,
  • 11 months later...
Just found this custom Alphacool NexXxos GPX. Just Bought it and will fit it this weekend on my Vapor X 280X 3GB.. Will take pics and let you know Temps.
http://www.alphacool.com/product_info.php/info/p1535_Alphacool-NexXxoS-GPX---ATI-R9-280X-M07---incl--Backplate---black.html
  • 2 weeks later...
Tested + Installed = http://linustechtips.com/main/topic/157429-alphacool-gpu-hf-14-universal-gpu-block/?p=5160512
