PCIE riser cable
2 hours ago, Ichigo16 said:
Now i'm aware that riser cables exist - and that's where my knowledge ends on them. I was wondering if it's possible to use one here, i would plug either wi-fi card (Gigabyte GC-WB1733D-I) or my sound card (Aim sc808) via said riser.
What i would like to know if this is even possible to do? If it is feasible then what should i look for when choosing said riser? also how much is such undertaking gonna cost lol
well considering you are NOT wanting to use one for the gpu as the previous replies wrongly assume (cmon' people, read the damn post!!!!!)
YES a riser cable will work fine for the WiFi or sound card.
I'm using one for my Soundblaster card no problems at all for the same reason, slot was covered by gpu.
https://www.amazon.com/dp/B0CP5L2YFS?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
luv how folks just fire out a response without actually thinking about the original question first.
