Hello,
I am trying to disassemble the back cover of my Gigabyte M28U monitor, but I had problem open it after finally changed the psu, and turn on the monitor half of the screen was off pitch black.
anyone knows how I can connect back this pin, it’s symmetrical there is one one the left and one on the right, the one on the left the same half of the monitor that works , the pins are rock solid attached instead the one on the right detached and I can’t put it back manually.
what can I do ?
thanks for any advice and help
https://linustechtips.com/topic/1633687-luminosity-problem/
You tore the pads off it so thats gonna require a repair. Luckily there are test points right next to them so I assume someone who is half capable should be able to do it.
https://linustechtips.com/topic/1633687-luminosity-problem/#findComment-16875468
