Intermittent No Power Issues
Go to solution Solved by adman29,
So, it's not the lights of the house that turn off, it's the lights on the motherboard turned off fully, but your response made me think of something. I went to the outlet and checked it, and the live hot came out when I pulled it from the box. I have secured the wire firmly (the terminal was just fully unscrewed) and have secured the outlet in the box more securely. Hopefully that's what was causing it.
Hello all,
I have this fixed with my wife's PC, but this keeps coming up from time to time. Basically what will happen, is that the PC will randomly go into a no power no post state. Usually the computer will show signs of life -- lights on the power/reset buttons on the Motherboard, however it will not boot whenever power is pressed on those, or the case power switch. Every time we've troubleshot this, taking it to another outlet will cause those lights to go out, and it will not respond to any power on/power off attempts. At least one time this has happened, we have replaced the PSU, and that fixed it, but what I'm starting to notice is that it might be time. For todays fix we did the following:
Unplugged computer (lost all lights)
Took to another room to test, no power on, no lights
<went to grab breakfast>
Attempted to switch to another PSU (backup that was given as RMA), no power on, no lights.
Attempted to switch to a known good PSU (mine, in my computer), no power on, no lights
Attempted to test by removing GPU
Tried PSU in my computer, it acted dead, I think that I just had the wrong cables hooked up for that test (mines an EVGA, hers is a Corsair, I think the 24pin cables are slightly different)
Tested all PSUs with the paperclip method, after some fiddling figured out that all worked as long as the right cables were plugged in
Attempted CMOS clear button on her PC
Tried RMA PSU with her computer, still didn't work
Tried original PSU with her computer, worked this time.
I believe from noticing it was dead to the end was probably 2.5 hours since we went to breakfast. I will also add, this happened with her old computer occasionally. I don't believe it's the outlet, as it tests fine with an outlet tester and also tests fine with a multimeter. I have the computer on a fairly nice Rocketfish surge protector as well. This has happened with storms, and when the weather's fine, but usually we notice it in the morning when she tries to turn on her computer. Does anyone have any ideas?
PC Specs:
Corsair RM750e
NZXT N7 B650E
Corsair Vengeance 16GB x2
AMD R7 7700
EVGA 1080Ti
https://linustechtips.com/topic/1633415-intermittent-no-power-issues/
3 minutes ago, adman29 said:
Hello all,
PC Specs:
Corsair RM750e
NZXT N7 B650E
AMD R7 7700
EVGA 1080Ti
l Think problem may from you house surge protector,can you try Connect power but without surge protector?
This could be a serious issue. You can't mix and match brands and modular power cables, they are proprietary. Without you diagnosing the original issue, you won't be able to know for sure.
If you're going to test your system with a different power supply (which you definitely should) make sure to use the cables that are included with that power supply.
Primary PC:
PSU tier list
How many watts do I need?
I got it tested with the right cables in the end, but it wasn't till the third attempt (second with right cables) that the system booted.
glad that you ruled that out. Worst case scenario is that mismatched power supply + cables = dead stuff so you dodged a bullet.
something about this makes me question the quality of power coming into/within your house, and if it fluctuates at times when you aren't able to catch it. it's also something that a surge protector may not protect against, because those are most often helpful for more severe power fluctuations, and some discrepancies may not be filtered out. Also will point out that surge protectors deteriorate over time, and if they have surge protected in the past, they are spent. I don't believe that's necessarily common knowledge.
I wouldn't recommend a UPS system since those can be pretty darn expensive, but do you have any other ways of changing the power conditions that the PC is exposed to? The lights going out fully when you turn the PC on raises an eyebrow as to the quality of your home's electrical quality.
Primary PC:
PSU tier list
