so i have 2x ddr4 ram running at 3000 mhz. (i confirm its dual channel in the terminal, my mobo has 2 slots anyways) a few days ago i was getting 14gibps and now 7 gibs when i run a test, in the meantime i increased zram from 50 percent to 75 and i dedicate 2 gb to igpu. i ran tests when pc was busy and idle but no luck. also my base clock speed is 102 mhz and my mobo is on the low end, gemini says zram isnt an issue but maybe ist base clock speed and the speed should be 25+ gibps. also now my pc feels sluggish, im running mx linux btw. you guys gotta know how to fix this, thx in advance if you let me know of your ideas.
update : i tried turning zram off and i get 8gibps
update2 : so its running at 86 degrees under no load but fans arent loud? and i had configured the fan graph to be fast
update 3 : ok cpu fan wasnt turning i replugged its cable and now temps are fine but still i get 7.5  gibps
I know it might not be secure, yeah vibecoding is cool but we shouldnt do smt unless we understand it and etc. thx but these disclaimers get old quick. maybe we shall be reminded frequently for we are stupid but i dont work at a nuclear powerplant.
https://linustechtips.com/topic/1632858-slow-ram-speed/
Both of these results appear too low.
3000 MT/s x 64 b/T = 192 Gbps, double that for dual channel
So you should be seeing 24 GB/s or 48 GB/s for dual channel (DDR4 3000 MT/s aka PC4-24000)
https://linustechtips.com/topic/1632858-slow-ram-speed/#findComment-16869689
11 hours ago, RONOTHAN## said:
Can you give full specs of the system (motherboard, CPU, RAM model, etc.), as well as the test you're using to run?
2200G, A520M K,
# dmidecode 3.4
Getting SMBIOS data from sysfs.
SMBIOS 3.3.0 present.
Handle 0x000B, DMI type 16, 23 bytes
Physical Memory Array
    Use: System Memory
    Error Correction Type: None
    Maximum Capacity: 128 GB
    Error Information Handle: 0x000A
    Number Of Devices: 4
Handle 0x0012, DMI type 17, 92 bytes
Memory Device
    Array Handle: 0x000B
    Error Information Handle: 0x0011
    Total Width: Unknown
    Data Width: Unknown
    Size: No Module Installed
    Form Factor: Unknown
    Set: None
    Locator: DIMM 0
    Bank Locator: P0 CHANNEL A
    Type: Unknown
    Type Detail: Unknown
Handle 0x0014, DMI type 17, 92 bytes
Memory Device
    Error Information Handle: 0x0013
    Total Width: 64 bits
    Data Width: 64 bits
    Form Factor: DIMM
    Set: None
    Locator: DIMM 1
    Type: DDR4
    Type Detail: Synchronous Unbuffered (Unregistered)
    Speed: 3000 MT/s
    Manufacturer: Unknown
    Serial Number: 00000000
    Asset Tag: Not Specified
    Part Number: CMK8GX4M1D3000C16
    Rank: 1
    Configured Memory Speed: 3000 MT/s
    Minimum Voltage: 1.2 V
    Maximum Voltage: 1.2 V
    Configured Voltage: 1.2 V
    Memory Technology: DRAM
    Memory Operating Mode Capability: Volatile memory
    Firmware Version: Unknown
    Module Manufacturer ID: Bank 3, Hex 0x9E
    Module Product ID: Unknown
    Memory Subsystem Controller Manufacturer ID: Unknown
    Memory Subsystem Controller Product ID: Unknown
    Non-Volatile Size: None
    Volatile Size: 8 GB
    Cache Size: None
    Logical Size: None
Handle 0x0017, DMI type 17, 92 bytes
Memory Device
    Error Information Handle: 0x0016
    Data Width: Unknown
    Set: None
    Locator: DIMM 0
    Bank Locator: P0 CHANNEL B
    Type: Unknown
Handle 0x0019, DMI type 17, 92 bytes
Memory Device
    Error Information Handle: 0x0018
    Data Width: 64 bits
    Form Factor: DIMM
    Set: None
    Locator: DIMM 1
    Type: DDR4
    Speed: 3000 MT/s
    Rank: 1
    Volatile Size: 8 GB
    Cache Size: None
    Logical Size: None
$ mbw -t0 2024
Long uses 8 bytes. Allocating 2*265289728 elements = 4244635648 bytes of memory.
Getting down to business... Doing 10 runs per test.
0    Method: MEMCPY    Elapsed: 0.29422    MiB: 2024.00000    Copy: 6879.159 MiB/s
1    Method: MEMCPY    Elapsed: 0.29343    MiB: 2024.00000    Copy: 6897.821 MiB/s
2    Method: MEMCPY    Elapsed: 0.29271    MiB: 2024.00000    Copy: 6914.694 MiB/s
3    Method: MEMCPY    Elapsed: 0.29430    MiB: 2024.00000    Copy: 6877.266 MiB/s
4    Method: MEMCPY    Elapsed: 0.29954    MiB: 2024.00000    Copy: 6756.937 MiB/s
5    Method: MEMCPY    Elapsed: 0.29138    MiB: 2024.00000    Copy: 6946.351 MiB/s
6    Method: MEMCPY    Elapsed: 0.30019    MiB: 2024.00000    Copy: 6742.464 MiB/s
7    Method: MEMCPY    Elapsed: 0.29974    MiB: 2024.00000    Copy: 6752.519 MiB/s
8    Method: MEMCPY    Elapsed: 0.29447    MiB: 2024.00000    Copy: 6873.412 MiB/s
9    Method: MEMCPY    Elapsed: 0.29157    MiB: 2024.00000    Copy: 6941.729 MiB/s
AVG    Method: MEMCPY    Elapsed: 0.29515    MiB: 2024.00000    Copy: 6857.423 MiB/s
https://linustechtips.com/topic/1632858-slow-ram-speed/#findComment-16869789
yea thats why im tryna fix it, but shouldnt it be 12 or 24 gibps?
https://linustechtips.com/topic/1632858-slow-ram-speed/#findComment-16869791
so yea turns out the test is single threaded,
$ sysbench memory --threads=4 --memory-block-size=1M --memory-total-size=20G run
sysbench 1.0.20 (using system LuaJIT 2.1.0-beta3)
Running the test with following options:
Number of threads: 4
Initializing random number generator from current time
Running memory speed test with the following options:
  block size: 1024KiB
  total size: 20480MiB
  operation: write
  scope: global
Initializing worker threads...
Threads started!
Total operations: 20480 (34627.44 per second)
20480.00 MiB transferred (34627.44 MiB/sec)
General statistics:
    total time:                          0.5878s
    total number of events:              20480
Latency (ms):
         min:                                    0.04
         avg:                                    0.09
         max:                                   11.68
         95th percentile:                        0.25
         sum:                                 1843.60
Threads fairness:
    events (avg/stddev):           5120.0000/0.00
    execution time (avg/stddev):   0.4609/0.08
but still not the promised 48 gibps
https://linustechtips.com/topic/1632858-slow-ram-speed/#findComment-16869793
Theoretical throughput is 48 GB/s not GiB/s. Converted to GiB/s the expected result would be around 44.8 GiB/s
You're most likely running into a bottleneck with some other component. Test might simply be CPU limited.
Generating random numbers is not free. Depending what device is used here (urandom?) that could turn into the limiting factor.
https://linustechtips.com/topic/1632858-slow-ram-speed/#findComment-16869825
I've got a 5900x paired with DDR4 3600 MT/s (PC4-28800). In dual channel this gives me a theoretical throughput of 57.6 GB/s, or 54.9 GiB/s.
When I run sysbench with the same settings you did, I actually get 86638.97 MiB/sec. When I increase the block size to 8M, it actually increases to 104571.75 MiB/sec! Way more than expected.
According to ChatGPT the reason I'm seeing such large numbers is the small block size. This has me measuring my CPU's L3 cache, rather than actual memory throughput. Here's what I see when I modify the benchmark as it suggested for my CPU:
sysbench memory --threads=12 --memory-block-size=1G --memory-total-size=20G run
sysbench 1.0.20 (using system LuaJIT 2.1.1720049189)
Number of threads: 12
  block size: 1048576KiB
  operation: write
  scope: global
Threads started!
Total operations: 12 (   52.09 per second)
12288.00 MiB transferred (53343.40 MiB/sec)
General statistics:
    total time:                          0.2298s
    total number of events:              12
Latency (ms):
         min:                                  152.52
         avg:                                  194.32
         max:                                  229.69
         95th percentile:                      231.53
         sum:                                 2331.85
Threads fairness:
    events (avg/stddev):           1.0000/0.00
    execution time (avg/stddev):   0.1943/0.02
Now that looks much more like what I'd expect.
Here's the LLM's full output, which also includes recommendations for benchmarks better suited to what you're trying to test.
On paper, your calculation is correct:
  • DDR4-3600
  • 3600 MT/s × 8 bytes per transfer (64-bit bus)
  • = 28.8 GB/s per channel
  • Dual channel → 57.6 GB/s theoretical peak (≈56–57 GB/s depending on units)
Yet you're measuring:
~104,572 MiB/s ≈ 109.6 GB/s
That’s almost 2× theoretical DRAM bandwidth.
This usually means you're not measuring DRAM bandwidth. Here's why.
1️⃣ You’re Mostly Measuring Cache Bandwidth
Your command:
sysbench memory --threads=4 --memory-block-size=8M --memory-total-size=20G run
Important points:
  • --memory-block-size=8M
  • 4 threads
  • Each thread repeatedly accesses its working block
On a Ryzen 9 5900X, you have:
  • 12 cores
  • 2 CCDs
  • 32 MB L3 cache per CCD
  • 64 MB total L3
With 4 threads × 8 MB = 32 MB total working set
That fits entirely inside one CCD's 32 MB L3 cache.
So what you're benchmarking is largely:
L3 cache bandwidth, not DRAM bandwidth.
Zen 3 L3 bandwidth is easily >100 GB/s aggregate, which matches your result almost perfectly.
2️⃣ Sysbench Is Measuring Copy/Sequential Operations
Sysbench memory test performs simple operations like:
  • Sequential read
  • Sequential write
  • memcpy-like operations
These:
  • Are highly prefetch-friendly
  • Hit cache aggressively
  • Benefit from write-combining
  • Are NUMA-local
So even when DRAM is involved, the CPU:
  • Prefetches ahead
  • Hides latency
  • Uses store buffers efficiently
This makes measured throughput higher than raw DRAM limits in small working sets.
3️⃣ You’re Seeing Cache-Line Traffic, Not Memory Bus Saturation
Modern CPUs move data in 64-byte cache lines.
If the benchmark:
  • Reuses data
  • Loops over the same block repeatedly
  • Doesn’t evict cache
Then many operations:
  • Never leave the CCD
  • Never hit the memory controller
  • Never consume DRAM bandwidth
So your 109 GB/s is very consistent with:
Zen 3 L3 cache bandwidth across 4 cores
4️⃣ How To Measure Real DRAM Bandwidth
To force actual memory traffic, you need to:
✔ Use a working set much larger than L3
For example:
or at least:
4 threads × 256M each
You want:
Working set ≫ 64 MB
✔ Use More Threads
Memory bandwidth scales with core count until the controller saturates.
Try:
--threads=12
✔ Or Use a Dedicated Bandwidth Tool
Better tools for DRAM bandwidth:
  • stream benchmark (classic memory bandwidth test)
  • mbw
  • lmbench
  • stress-ng --stream
STREAM on a Ryzen 5900X with DDR4-3600 typically reports:
~45–55 GB/s real sustained bandwidth
Which aligns with theory.
5️⃣ Unit Subtlety (Minor Detail)
You’re seeing:
104571.75 MiB/sec
Convert properly:
104,571 MiB/s × 1.048576 = 109.6 MB/s (decimal GB/s)
Even then:
109.6 GB/s > 57.6 GB/s
So units are not the main cause — cache effects are.
✅ Final Answer
Your benchmark result is higher than theoretical DRAM bandwidth because:
You are mostly measuring L3 cache bandwidth, not main memory bandwidth.
Your working set (32 MB total) fits entirely in one Zen 3 CCD's L3 cache, which can deliver >100 GB/s aggregate bandwidth across multiple cores.
If you increase the memory block size well beyond 64 MB, your measured bandwidth will drop into the expected ~50–55 GB/s range.
If you'd like, I can also explain how Zen 3’s dual-CCD design affects memory scaling and why cross-CCD tests behave differently — it's quite interesting.
https://linustechtips.com/topic/1632858-slow-ram-speed/#findComment-16870025
  operation: write
  scope: global
Threads started!
General statistics:
    total time:                          0.2298s
Latency (ms):
         min:                                  152.52
         avg:                                  194.32
         max:                                  229.69
         sum:                                 2331.85
Threads fairness:
  Hide contents
  • DDR4-3600
Your command:
Important points:
  • 4 threads
  • 12 cores
  • 2 CCDs
  • 64 MB total L3
  • Sequential read
  • Sequential write
These:
  • Are NUMA-local
  • Prefetches ahead
  • Hides latency
If the benchmark:
  • Reuses data
For example:
or at least:
You want:
Working set ≫ 64 MB
✔ Use More Threads
Try:
--threads=12
  • mbw
  • lmbench
You’re seeing:
104571.75 MiB/sec
Convert properly:
Even then:
✅ Final Answer
yea the cpu is a hero. can you try mbw with a single thread too?
$ sysbench memory --threads=4 --memory-block-size=1G --memory-total-size=20G run
  operation: write
  scope: global
Threads started!
Total operations: 20 (   12.95 per second)
20480.00 MiB transferred (13261.98 MiB/sec)
General statistics:
    total time:                          1.5409s
Latency (ms):
         min:                                  165.46
         avg:                                  293.82
         max:                                  390.67
         95th percentile:                      383.33
         sum:                                 5876.39
Threads fairness:
    events (avg/stddev):           5.0000/0.00
    execution time (avg/stddev):   1.4691/0.06
so ram is too good for cpu?
Edit:
$ # 1. Download the source
wget https://www.cs.virginia.edu/stream/FTP/Code/stream.c
# 2. Compile with optimizations and multi-threading (OpenMP)
gcc -O3 -fopenmp -DSTREAM_ARRAY_SIZE=100000000 stream.c -o stream
# 3. Run it using all 4 of your Ryzen 2300G threads
export OMP_NUM_THREADS=4
./stream
--2026-02-28 13:42:40--  https://www.cs.virginia.edu/stream/FTP/Code/stream.c
Resolving www.cs.virginia.edu (www.cs.virginia.edu)... 128.143.67.8
Connecting to www.cs.virginia.edu (www.cs.virginia.edu)|128.143.67.8|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 19967 (19K) [text/x-csrc]
Saving to: ‘stream.c’
stream.c                 100%[==================================>]  19.50K   104KB/s    in 0.2s
2026-02-28 13:42:42 (104 KB/s) - ‘stream.c’ saved [19967/19967]
STREAM version $Revision: 5.10 $
This system uses 8 bytes per array element.
Array size = 100000000 (elements), Offset = 0 (elements)
Memory per array = 762.9 MiB (= 0.7 GiB).
Total memory required = 2288.8 MiB (= 2.2 GiB).
Each kernel will be executed 10 times.
 The *best* time for each kernel (excluding the first iteration)
 will be used to compute the reported bandwidth.
Number of Threads requested = 4
Number of Threads counted = 4
Your clock granularity/precision appears to be 2 microseconds.
Each test below will take on the order of 59507 microseconds.
   (= 29753 clock ticks)
Increase the size of the arrays if this shows that
you are not getting at least 20 clock ticks per test.
WARNING -- The above is only a rough guideline.
For best results, please be sure you know the
precision of your system timer.
Function    Best Rate MB/s  Avg time     Min time     Max time
Copy:           32260.8     0.051211     0.049596     0.056252
Scale:          20122.2     0.084704     0.079514     0.095905
Add:            23052.3     0.111081     0.104111     0.127775
Triad:          23743.5     0.105728     0.101080     0.117723
Solution Validates: avg error less than 1.000000e-13 on all three arrays
Gemini suggested this and said 30-36Gibps is expected and real world speed is 75-80% of the max
https://linustechtips.com/topic/1632858-slow-ram-speed/#findComment-16870063
Sure
sysbench memory --threads=1 --memory-block-size=1M --memory-total-size=20G run
sysbench memory --threads=1 --memory-block-size=8M --memory-total-size=20G run
sysbench memory --threads=1 --memory-block-size=1G --memory-total-size=20G run
  • 1M > 20480.00 MiB transferred (41047.70 MiB/sec)
  • 8M > 20480.00 MiB transferred (40541.64 MiB/sec)
  • 1G > 20480.00 MiB transferred (17690.34 MiB/sec)
mbw -t0 1024
AVG    Method: MEMCPY    Elapsed: 0.05031    MiB: 1024.00000    Copy: 20354.575 MiB/s
So yeah, single threaded seems limited by the CPU's speed
https://linustechtips.com/topic/1632858-slow-ram-speed/#findComment-16870375
