Need some help with data back up
Go to solution Solved by Madii,
My approach would be to:
  • install an OS onto the new pc with only the new parts. Get that system situated with driver updates etc
  • Grab the old drive and plug it into the new PC as an additional drive
  • boot into the new OS on the new drive.
  • gain access to the old files on the old drive. Move over whatever he tells you to move over.
  • extract the old drive and hold onto it for a few months to a year in case you forgot something.
  • there’s functionally no limit to how long you can hang on to that old drive, but it’s also a pain in the ass to keep track of somebody else’s data lol
I’ve used this method for my own pc upgrades as well as upgrading the PC my mom runs her engineering company off of. In her case, she primarily runs her business off of her google workspace storage, but there’s still stuff that ends up living in the downloads folder that turns out to be mission critical. Which is why you hold onto it for a while 🙂 good luck out there!
So I'm currently in the process of replacing my Dad's old computer as it is failing as the CPU is semi fried. Anyway I am going to build the system myself, my main question is how would I back up all of his files on his old HDD to the new-ish SSD? I'm asking this as I am aware you can clone storage devices but I've only ever seen it done just to replace the storage device (like upgrading the HDD to an SSD on your old gaming PC) on the same device, never in a completely different system.
For context my Dad's current computer has:
Ryzen 3 2200G (using iGPU)
ASUS Prime A320M-K
ADATA 1x8GB 2400Mhz DDR4 UDIMM
WD Blue 1TB 7200RPM HDD
Windows 10 (unable to upgrade to WIndows 11)
And I plan to replace it with:
Intel Core i5 12400 (using iGPU)
Gigabyte B760M Gaming X WIFI6E DDR4 GEN5 mATX
Kingston Fury Beast 2x8GB 3200Mhz DDR4 UDIMM
Samsung 860 EVO 500GB SSD (Spare one laying around)
Windows 11
I know how to build computers but data backup is an unfamiliar territory for me. Annoyingly whoever built my Dad's old computer kinda has the files like everywhere so how would I back up only his files and not like the operating system or anything onto the mentioned SSD? If you're wondering the computer is only for office work (like viewing and editing PDFs) and watching YouTube videos. And yes 500GB is enough for him as he has barely used 50GB (excluding the OS) on the 1TB HDD as most of the work he does is cloud based anyway. And I can get the old computer itself stable to do a data transfer or whatever. If possible please suggest a video as I don't know what to search up.
Edited by JaspreetNZ
Forgot to mention.
https://linustechtips.com/topic/1632188-need-some-help-with-data-back-up/
If the two computers can work at the same time in the same network, you can just share a folder, where is data is ( usually all of it should be in his user profile )
and you can always just take the HDD out and plug in to the new PC, and just copy the folders with the data.
CPU : Intel 14gen i7-14700K
COOLER :  Thermalright Peerless Assassin 120 White + Thermaltake toughfan 12 white + Thermal Grizzly - CPU Contact Frame Intel 13./14. +  Coollaboratory Liquid Ultra
GPU : MSI RTX 2070 Armor @GPU 2050MHz Mem 8200MHz -> USB C 10Gb/s cable 2m -> Unitek 4x USB HUB 10 Gb/s (Y-HB08003)
MOBO : MSI MEG Z690 UNIFY
RAM :  Corsair VENGEANCE DDR5 RAM 64 GB (2 x 32 GB) 6400 MHz CL32 (CMK64GX5M2B6400C32)
SSD : Intel Optane 905P 960GB U.2 (OS) + 2 x WD SN850X 4TB + 2 x PNY CS3140 2TB + PLX88024 PCIe switch (PCIE 4.0 x8 -> 4 x M.2 PCIe 4.0 x4) -> 4 x Plextor M8PeG 1TB + flexiDOCK MB014SP-B -> Crucial MX500 2TB + GoodRam Iridium PRO 960GB + Samsung 850 Pro 512GB
HDD : WD White 18TB WD180EDFZ + SATA port multiplier adp6st0-j05 (JMB575) ->  WD Gold 8TB WD8002FRYZ + WD Gold 4TB WD4002FYYZ + WD Red PRO 4TB WD4001FFSX + WD Green 2TB WD20EARS
EXTERNAL
HDD/SSD :
XT-XINTE LM906 (JMS583) -> Plextor M8PeG 1TB + WD My Passport slim 1TB + LaCie Porsche Design Mobile Drive 1TB USB-C + Zalman ZM-VE350 -> Goodram IRDM PRO 240GB
PSU :  Super Flower leadex platinum 750 W biały -> Bitfenix alchemy extensions białe/białe + AsiaHorse 16AWG White
UPS :  CyberPower CP1500EPFCLCD -> Brennenstuhl primera-line 8 -> Brennenstuhl primera-line 10
LCD : LG 32UD59-B + LG flatron IPS236 -> Silverstone SST-ARM11BC
CASE :  Fractal R5 Biały + Lian Li BZ-H06A srebrny + flexiDOCK MB014SP-B + 6 x Thermaltake toughfan 14 white + Thermalright TL-B8W
SPEAKERS :  PC -> TOSLINK 2m -> Linkfor ULK073 1x4 Digital SPDIF Splitter (B07MJ4TLWQ) -> TOSLINK 0.5m -> Aiyima A80 ( or Aune S6 Pro -> RCA ->  Aiyima A80 ) -> Polk S20e black -> Monoprice stand 16250
HEADPHONES : PC -> TOSLINK 2m -> Linkfor ULK073 1x4 Digital SPDIF Splitter (B07MJ4TLWQ) -> TOSLINK 0.5m -> Aune S6 Pro -> 2 x Monoprice Premier 1.8m 16AWG 3-pin XLR -> Monoprice Monolith THX AAA 887 -> 4-pin XLR na 2 x 3.5mm 16 cores OCC 2m Cable -> HiFiMAN Edition XS -> sheepskin pads + 4-pin XLR na 2 x 2.5mm ABLET silver 2m  Cable -> Monoprice Monolith M1060 + Brainwavz HM100 -> Brainwavz sheepskin oval pads + Wooden double Ɪ Stand + Audio-Technica ATH-MSR7BK -> sheepskin pads + Multibrackets MB1893 + Sennheiser Momentum 3 +  Philips Fidelio X2HR/00 + JBL J88 White
MIC :  Tonor TC30 -> Mozos SB38
KEYBOARD : Corsair STRAFE RGB Cherry MX Silent (EU) + Glorious PC Gaming Race Stealth Slim - Full Size Black + Kensington VeriMark / PQI MyLockey
MOUSE :  Logitech MX ERGO + 2 x Logitech MX Performance + Logitech G Pro wireless + Logitech G Pro Gaming -> Hotline Games 2.0 Plus + Corsair MM500 3xl + Corsair MM300 Extended + Razer goliathus control
CONTROLLERS :  Razer Wolverine V3 Tournament Edition 8K PC (B0F94C9C43) -> brainwavz audio Controller Holder UGC2 + Microsoft xbox series x controller pc (1VA-00002) + Ravcore Javelin
NET :  Intel E810-XXVDA2 2 x 25GbE SFP28 (PCIE 4.0 x8) -> 2 x FTLX8571D3BCV-IT -> 2 x Digitus (DK-HD2533-05/3) -> Qnap TS-932X-2G + 2 x ASUS ZenWiFi Pro XT12
NAS :  Qnap TS-932X-2G -> Kingston 16GB 2400Mhz CL14 (HX424S14IB/16) -> 9 x Crucial MX500 2TB -> 2 x FTLX8571D3BCV-IT -> Noctua NF-P14s redux 1200 PWM -> QNAP TR-004
Thanks for the advice
