Bought used Z790-A board, and it’s artifacting, there was one vga grounding pin bent in the bottom right, but we fixed it best we could, to no avail though. I bought the cpu with it, i just dont want to buy a new motherboard incase its the cpu. Not gpu or cable related, and we flashed bios.
https://linustechtips.com/topic/1631697-need-help/
System specs please,
Are you using a gpu ?
Did you try to update your bios ?
Did you try another HDMI cable and monitor ?
To me the mobo isn't the first suspect.
(Memtest86 included in the bios ?)
Edited by leclod
If you don't quote us, we won't know you answered
https://linustechtips.com/topic/1631697-need-help/#findComment-16862029
