CPU cooler
Go to solution Solved by Poinkachu,
3 minutes ago, Misaa said:
I'm looking to get a new CPU and motherboard
ASUS X870 MAX GAMING WIFI7
AMD Ryzen 7 7800X3D CPU
I have a Corsair iCUE H150i RGB PRO XT and I wonder if it'll fit due to the larger AM5 socket?
I know it's probably a dumb question I could've just looked for for 10 minutes, but I find it a little difficult
Not 10 minutes. 30 seconds
https://linustechtips.com/topic/1631651-cpu-cooler/
Refresh before you reply
https://linustechtips.com/topic/1631651-cpu-cooler/#findComment-16861656
i have a corsair H100i RGB Platinum, i had the same exact question because i only had the AM4 bracket. yes it fits AM5, AM4 and AM5 corsair brackets (i belive all AM4 for all coolers at this point) are compatible.
i asked corsair support for an AM5 bracket but they told me it was the same as AM4
                   -`                    y0ur5h4d0w@Darkness
                  .o+`                   -------------------
                 `ooo/                   OS: Arch Linux x86_64
                `+oooo:                  Host: Darkness
               `+oooooo:                 Kernel: Latest
               -+oooooo+:                Packages: Only what i need to keep it simple
             `/:-:++oooo+:               Shell: ZSH
            `/++++/+++++++:              Main Monitor: LG Ultragear LG 27GS85Q
           `/++++++++++++++:             Secondary Monitor: Asus MG28UQ
          `/+++ooooooooooooo/`           DE: Plasma Always Bleeding Edge
         ./ooosssso++osssssso+`          WM: kwin
        .oossssso-````/ossssss+`         Theme: Breeze-Dark [GTK2], Breeze [GTK3]
       -osssssso.      :ssssssso.        Icons: Breeze-dark [GTK2/3]
      :osssssss/        osssso+++.       Terminal: Kitty
     /ossssssss/        +ssssooo/-       Terminal Font: Noto Color Emoji 17 FreeMono 13
   `/ossssso+/:-        -:/+osssso+-     CPU: AMD Ryzen 7 9800X3D (16) @ 5.307GHz
  `+sso+:-`                 `.-/+oso:    GPU: AMD ATI Radeon RX 7800 XT
 `++:.                           `-/+/   GPU: AMD ATI Radeon Graphics
 .`                                 `/   Memory: 61830MiB
https://linustechtips.com/topic/1631651-cpu-cooler/#findComment-16861670
So I guess it worked perfectly fine? AM5 with AM4?
https://linustechtips.com/topic/1631651-cpu-cooler/#findComment-16861693
exactly, AM4 brackets and AM5 brackets are exactly the same, you don't need to buy anything else
https://linustechtips.com/topic/1631651-cpu-cooler/#findComment-16861720
