My current setup is
MSI B450‑A PRO MAX
AMD Ryzen 5 3600 with SilentiumPC Spartan 4 100mm cooler
- 32gb (4x8) 3600MHz CL 16 RAM
- SilentiumPC Vero L3 600W 80 Plus Bronze
What would be the best possible CPU to buy on AM4 platform for this 5070 to get as little bottleneck as reasonably possible?
Also I'm aware I will most likely need to upgrade that PSU.
https://linustechtips.com/topic/1630858-cpu-for-5070/
R7 9800X3D, Arctic Liquid Freezer III 360 ARGB, ASRock X870E TAICHI, Kingston FURY 64GB (2x32GB) 6000MT/s CL30 Beast Black RGB , Gigabyte RTX 4090 Gaming OC, Windows 11
https://linustechtips.com/topic/1630858-cpu-for-5070/#findComment-16856353
The forbidden word among PC gamers. AM4 should be sufficient for a 5070, there are options like 5800x3d or 5950x depending on your use case, gaming or creativity
MY PC: Ryzen 9 3900x | Asus Dual RTX 4070 OC | 128GB Kingston Fury DDR4-3600 Ram | 512GB 5000 mb/s TeamGroup M.2 NVME | 2TB + 1TB HDD (Western Digital | Thermalright Frozen Notte V2 360mm AIO | Hyte Y60 Snow White| Corsair HX1000 PSU |
https://linustechtips.com/topic/1630858-cpu-for-5070/#findComment-16856459
