need help on my audio setup
Current setup
1. PC
2. audioengine d1 dac (supports only 2 RCA)
3. one RCA y splitter
4a. klipsch subwoofer r8sw
4b. bitway amp (can only support 2 passive speakers)
       a. passive speakers
(FMOD on its way)
(i have a ground isolator)
Problem:
1) when i plug my head phone into the d1 dac, i get ~145hz humming noise (i have a ground isolator and it does not work)// no humming noise when the splitter is removed.
2) I get bass in my speakers. I want the speakers to only play 100hz and up
Solution One:
1) installed FXsound and ordered harrisonlab FMOD inline 100hz hpf
Problem to solution 1:
1) fmod does not completely eliminate bass
2) using fxsound, i lowered db for frequencies lower than 100hz, but now the bass is too weak
Solution 2:
1) Just buy minidsp 2x4 HD
Problem:
1) I spent too much already. Not too eager to spend $225+ usd
What can I do to
1) eliminate bass in my speakers. I want the speakers to only play 100hz and up
2) plug my head phone into the d1 dac and not getting humming noise from speakers (this is caused by ysplitter)
  • CPU
    9900KS @ 5.0 avx offset 0/ cache 4.7/ @1.33v
  • Motherboard
    asus strix ROG z390-i
  • RAM
    8gb x2 G.skill ddr 4 3600 (OCed to 4000 17-19-19-39 @1.4v)
  • GPU
    Asus Strix OC RTX 3080 10GB
  • Case
    Corsair 280x Crystal
  • Storage
    1tb Samsung SSD + 2x (512gb Samsung) SSD
  • PSU
    Seasonic GM 650 650Watt Gold (semi-modular)
  • Display(s)
    LG34gk950g
  • Cooling
    H115i platinum/ 2x NF-A14 (GPU intake)/ 2xNFA14 (H115i radiator exhaust fan) 2x Corsair ML PRO 140(front intake) / 1x NF-A8 (exhaust)/ 2 x Corsair LL 120 (GPU deshroud fans)
  • Keyboard
    Corsair K70 LUX MX RED/ Microsoft Designer Keyboard Bluetooth
  • Mouse
    Corsair Harpoon RGB
  • Sound
    Audioengine A2+/ Audioengine d1 dac/ B&O h6
https://linustechtips.com/topic/1629414-need-help-on-my-audio-setup/
This will never happen with just a simple splitter.
Don't buy a minidsp.  I'm sure if you look on eBay you'll find a hundred, old school, Yamaha, Cinema DSPs for well under 100 dollars.  I know they're bulky but once set up they can be tucked away and never touched again.  They're cheap cause everyone is swapping them out for soundbars these days
example one in the UK
 With all the Trolls, Try Hards, Noobs and Weirdos around here you'd think i'd find SOMEWHERE to fit in!
miniDSP is very expensive if you want to get the dirac license, I put one on my tower speakers and it helped but didn't solve the problem I was having.  I think it's due to room treatment that I get a boost on anything that sounds like a kickdrum.  Like @SquirrelChunk said a cheap AVR on the used market will do everything you are wanting.  I'm unfamiliar with your other purposed solution but it sounds like it isn't easy to accomplish what you want this way.
Audio go Brrrrrr
thanks for the reply bros!
Interesting ideas.
I read up more on this and unfortunately AVR will not do everything I am wanting unless its expensive.
Cheap AVRs do not have true crossovers.
It is basically the same thing as my inline fmod except more expensive and bulkier.
I will test my inline fmod and if I feel that the slope is too gradual, it seems that minidsp is the only way.
Once again, thanks for the response
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    LG34gk950g
  • Cooling
  • Keyboard
  • Mouse
    Corsair Harpoon RGB
  • Sound
On 1/1/2026 at 8:56 AM, Blue4130 said:
Have you thought about using actual crossovers?
yeah i did but they are massive! I need an elegant solution though.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    LG34gk950g
  • Cooling
  • Keyboard
  • Mouse
    Corsair Harpoon RGB
  • Sound
On 1/1/2026 at 9:39 AM, Psittac said:
Used market FTW
yeah i am looking at some used minidsp 2x4 right now but lets see how the inline fmods perform first
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    LG34gk950g
  • Cooling
  • Keyboard
  • Mouse
    Corsair Harpoon RGB
  • Sound
