Hello, due to some personal reasons, I will have to move my PC with me weekly, and I am looking to downsize it. I will have to take it with me on the train, preferably in my suitcase, which is 55x36x24cm. I have at most 850 RMB or 120USD. I''d rather buy domestically off taobao or any other chinese site, but if my only option is to import a case then so be it.
I am currently running the deepcool cg330 3f, which is 40L. I'd like to get that down to 20L~.
Parts list: https://pcpartpicker.com/list/tGQ3VF
I am looking to still have my all white clean aesthetic with the rgb and LCD aio. Glass side panel is mandatory. I would prefer to be able to vertically mount my GPU while still seeing the lcd aio, but if it pushes it over maybe 25L~ or doesn't fit in the suitcase, then I'll just take the smallest thing that fits everything. Would like a rear cable management thing to tidy up all my cable extentions. Since I have a black PSU, I would like than to be hidden,but if not, I'm ok with just applying vinyl to the psu to make it white.
Thanks, if you need any more info/ have questions, just lmk!
https://linustechtips.com/topic/1629216-need-help-downsizing/
The best thing to do is go Mini ITX and find parts that fit your aesthetic goals. I don’t personally use RGB or LCD screens since I use Afterburner stats on my display, so I won’t be much help with those.
PLEASE QUOTE ME IF YOU ARE REPLYING TO ME
Framework Laptop: Intel Core i7-1165G7 @ 4.7GHz, 32GB DDR4 @ 3200MHz, ADATA Legend 850 2TB NVMe, Intel Irix XE Graphics, 13.5" 2256x1504 Display, Linux Mint 22.2
Home Server: Intel Core i7-12700E @ 2.1GHz, MSI Pro H610M-G WIFI DDR4, 64GB Crucial Pro DDR4 @ 3200MHz, Thermalright AXP120-X67, Rosewill RSV-Z2700u Ubuntu Server 24.04.3 LTS
Home NAS: Intel Xeon E5-2690 v4 @ 2.6GHz, Supermicro X10SRL-F, 256GB DDR4 @ 2400MHz, 50TB Storage, Intel X570-DA2 10GB NIC, NVIDIA Quadro P2200, TrueNAS Scale CE 25.04.2.4
https://linustechtips.com/topic/1629216-need-help-downsizing/#findComment-16844722
somehow I foresee impending disaster with this plan.
PC's with huge gpu's aren't meant to be moved around weekly, that's why they invented laptops. 😉
https://linustechtips.com/topic/1629216-need-help-downsizing/#findComment-16846122
Any chance you could get a thin client and remote into your PC when you need to be away? Obvious disadvantage is the requirement for a stable internet connection; and the cost of keeping the PC on while you're away. Would be much safer than transporting a PC around with you.
Main PC [ CPU AMD Ryzen 9 7900X3D with H150i ELITE CAPPELIX  GPU Nvidia 3090 FE  MBD ASUS ROG STRIX X670E-A  RAM Corsair Dominator Platinum 64GB@5600MHz  PSU HX1000i  Case Lian Li PC-O11 Dynamic  Monitor LG UltraGear 1440p 32" Nano IPS@180Hz  Keyboard Keychron Q6 with Kailh Box Switch Jade  Mouse Logitech G Pro Superlight  Microphone Shure SM7B with Cloudlifter & GoXLR ]
Server [ CPU AMD Ryzen 5 5600G  GPU Intel ARC A380  RAM Corsair VEGEANCE LPX 64GB  Storage 16TB EXOS ]
Phone [ Google Pixel 8 Pro, 256GB, Snow ]
https://linustechtips.com/topic/1629216-need-help-downsizing/#findComment-16846582
