techhelp Te h help
Solved by BiotechBen,
5 minutes ago, La2nDart said:It is now sitting at code 31, which just says memory installed. I can get to bios, it detects my drives.
Clear CMOS by shorting the pins, that will set it all back to the default, and should start with memory training.
If that doesn't fix it: set your RAM to the base 4800 speed and see if it posts then. If it still doesn't get into windows: you may have a defective component.
