sp120 are garbage fans. If you need multiple cheap fans, get something like a bitfenix spectre pro. or AP121 or gentle typhoons, recommended would be noctuas.
CPU: Intel Core i7 2600k | Mootherboard: ASUS P8z68v-Pro | GPU: EVGA GTX780Ti 3GB | RAM: Kingston HyperX Genesis 8GB (4GBx2) 1600mhz | PSU: Corsair AX760 | STORAGE: Samsung 840 Pro 512GB | COOLER: Noctua NH-C14 | CASE: Fractal Design Define R4 Pearl Black | Operating SystemWindows 7 Professional 64-bit |
https://linustechtips.com/topic/162908-120mm-fan-for-push-pull/#findComment-2167865
Hyperboreas are dirt cheap and amazing.
You can buy some for your PC and have cash left over to buy one or two for your dog.
Not really dirt cheap anymore. They're great but are $10 USD now instead of $7 >.>
I feel partially responsible for raising their popularity and prices.  -_-
https://linustechtips.com/topic/162908-120mm-fan-for-push-pull/#findComment-2167886
oh, well damn.
Still really good for 10$ I guess. Better than 15$ a pop.
Error: 410
https://linustechtips.com/topic/162908-120mm-fan-for-push-pull/#findComment-2167894
still want push pull it's just me.
i'll check those fans out. ty
Just watch out, the NB E-loops need a gasket put between it and the rad in pull, the design of the fan blades means they may touch the rad.
https://linustechtips.com/topic/162908-120mm-fan-for-push-pull/#findComment-2168362
