Apologies if I didn't use proper tags, this is my first time using this forum.
Specs:
Mobo: Gigabyte B650 Eagle AX
CPU: R7-7800X3D
RAM: Corsair Vengeance DDR5 16GBx2 @ 5200MT/s 40-40-40-77
GPU: Gigabyte Nvidia 4070Ti
BIOS Version: F34a
This is an NZXT prebuilt since I did not build another PC at the time.
Problem: When using two or more sticks of RAM, my PC will bluescreen and enter recovery mode. The error that throws is kernel heap pile up. I forget the exact wording, but that is the gist of it. I can throw in two sticks and it will survive for a few days to about a week and a half max before bluescreening during use or sometimes it just won't boot. This started roughly 3mo after I bought the PC in March or so of 2024. When the issue first arose, it would not post and I didn't use it for about two weeks. During that time, I contacted NZXT customer support and they were not much help as I did their entire troubleshoot checklist and wanted me to send my PC back to them for them to troubleshoot and fix and I did not want to risk it getting damaged in shipping as then I would be the one at fault for it and this is an expensive build. The motherboard that was initially built with the PC did not have debug lights, so I went out and bought a new motherboard with debug lights to give me an idea of where to look, and the light for RAM was on. I removed one stick of RAM and it booted up just fine, no issues. I later on decided to replace the RAM thinking that maybe it was just a bad kit. I bought the Corsair Vengeance I'm using now(I used that in my previous build and I had zero problems so that's what I stuck with). PC took both sticks just fine, had no issues until maybe a month or so later, I got bluescreens with the error I mentioned earlier. I removed one stick and it has been working just fine, but some games I can really feel a performance hit(Star Citizen for example). During one of my sessions in Star Citizen, I mentioned this issue and someone recommended updating my BIOS. I went from the very first BIOS version to F34a. I put the second stick in and it worked well for a little bit(roughly two or so weeks). I removed the second stick and that's what I have been using pretty much all the time with my PC. Recently, I looked up my motherboard compatibility and I found that my RAM is not fully compatible with my motherboard and CPU. I went into the BIOS and tweaked the speeds down thinking that by tuning it down a bit should help it be more stable with two sticks in, and like before, it lasted about a week or so. At this point, I am pretty unsure what my next steps are between buying a set of fully compatible RAM(and those prices are WAY out of my budget lol) or maybe buying a new motherboard that states its fully compatible with my current CPU and RAM. If y'all have any sort of ideas of things I could try, I am all ears. Thank you for your time reading and any and all help is greatly appreciated.
https://linustechtips.com/topic/1628581-ram-causing-problems-for-over-15yr/
Are you using A2 and B2 RAM slots?
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
You can make sure it's really not your RAM by running a memory test with memtest86+
https://memtest.org/
You will need a USB drive to flash to, make sure you don't have important things on it.
If you are on Windows, run the USB Installer and then boot from the USB drive.
Maybe you can start looking for other things once you've confirmed it definitely is or isn't your RAM.
Actually... you can't....
Had the infamous "vengeance" ram... issues for years... memtest etc always showed "no errors"...
Eventually swapped out the ram to proper ram (trident z) and the issues immediately and completely vanished....
What it is, your RAM isn't "faulty" hence memtest comes clean but it's not really compatible with your cpu, hence crashes bsods etc occur frequently....
Memtest etc does *not* simulate a windows environment and thus is almost entirely useless (it *will* find faulty ram though, however... 🤷)
11 hours ago, RealEirith said:
[wall of text...]
Ok, did you ever swap out your RAM?
Which brand model (if so)?
If I was you I'd try to find out what's the equivalent to AM4 bdies for AM5 and simply buy that (gonna be pricey but it is what it is)
NZXT prebuilt
Warranty?
Alternatively: buy Crucial (I know I know...) 5600 RAM, without heatspreaders if you have to.... Afaik that should be the most compatible AM5 ram, just a hunch tho.
-Scott Manley, 2021
yes, that's what I meant. Make sure the RAM modules themselves aren't faulty first (they are probably not, but it's good to check.)
Then you can troubleshoot further.
https://www.gigabyte.com/Motherboard/B650-EAGLE-AX-rev-10-11/support#support-memsup
This is the compatibility checking website for your motherboard.
Check the exact model number on the RAM modules and see if they are officially supported.
