3DS XL Camera not functioning.
Go to solution Solved by WVLTT,
Ah. Confirms my suspicion. The right rear camera is indeed broken.
I have an old 3DS XL. The front camera or back cameras will not work. Just a black screen, and the system will lock up.
It is running the latest software.
I have tried safe mode whatever.
I have reseated the ribbon cable.
I have factory reset the system.
When I went into settings to recalibrate the cameras, I do get live video feed from the rear cameras. So I know they work to some extent. Advice?
https://linustechtips.com/topic/1628306-3ds-xl-camera-not-functioning/
1 minute ago, WVLTT said:
From what I can see, It doesn't look like it. I think it may be that the right rear camera is fried. I will check with multimeter hold on.
In that case you would need to replace it. I found this first result on amazon to search ``Replacement Camera``: https://a.co/d/4YY1ti6
