Hello All,
I need two monitors for work, would prefer two 27inch. They do not need all the bells and whistles of gaming. I would just ask that they are 1080p, decently bright, IPS, and have both HDMI and Display Port. I have a very tight budget and would love any help in finding deals in the next couple weeks. I also need a desk mountable arm to hold both of them (without drilling) but I don't imagine this will be hard to find though recommendations are welcome.
Thank you!
https://linustechtips.com/topic/1627996-monitors-for-work/
Any particular reason you want 1080p? For 27" I'd highly recommend 1440p, especially if it's for work.
Otherwise, have a look at the monitor lists and buying guides here: https://www.displayninja.com/
https://linustechtips.com/topic/1627996-monitors-for-work/#findComment-16835955
5 hours ago, dar998 said:
Hello All,
Thank you!
how tight is the budget. Helps give recommendations if we know what you can actually spend.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1627996-monitors-for-work/#findComment-16836023
The software I work with does not scale to 1440 well, it breaks the UI
https://linustechtips.com/topic/1627996-monitors-for-work/#findComment-16836364
