Just now, BulletHail said:
Hi, I have no signal when i connect the gpu, when there is no gpu the PC runs perfectly and boots into windows. The GPU is the RX580 8gb version. Thank you.
While the pc turns on, there is no display.
This is even when the monitor is connected to the Mobo instead of GPU
Just now, Blasty Blosty said:
Have you tried clearing the CMOS?
And can you try this GPU in another system?
Hi, i forgot to mention I have another GPU and the the display worked. The fans on the gpu spin for 10 seconds before turning off
This probably means that your GPU is defective.
One way you can tell is by installing your GPU in another computer to confirm if it causes the same issue.
There is an option in most BIOSes to select which graphics adapter is used at boot (iGPU or PCIe GPU) but it don't think it will prevent video output unless the GPU is defective. You can always try to clear the CMOS memory in case there is some corrupted values but I doubt it will solve your issue because the iGPU seems to be working correctly.
Good luck !
P.S. your system specs would help.
Tried everything listed here?
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
How old is the PC you're connecting the RX 580 to?
Does the problem persist with CSM enabled? If not, you have a UEFI/GOP issue.
sounds like a dead GPU to me, if another GPU works there's not much more to test except testing the RX580 on another system
                   -`                    y0ur5h4d0w@Darkness
                  .o+`                   -------------------
                 `ooo/                   OS: Arch Linux x86_64
                `+oooo:                  Host: Darkness
               `+oooooo:                 Kernel: Latest
               -+oooooo+:                Packages: Only what i need to keep it simple
             `/:-:++oooo+:               Shell: ZSH
            `/++++/+++++++:              Main Monitor: LG Ultragear LG 27GS85Q
           `/++++++++++++++:             Secondary Monitor: Asus MG28UQ
          `/+++ooooooooooooo/`           DE: Plasma Always Bleeding Edge
         ./ooosssso++osssssso+`          WM: kwin
        .oossssso-````/ossssss+`         Theme: Breeze-Dark [GTK2], Breeze [GTK3]
       -osssssso.      :ssssssso.        Icons: Breeze-dark [GTK2/3]
      :osssssss/        osssso+++.       Terminal: Kitty
     /ossssssss/        +ssssooo/-       Terminal Font: Noto Color Emoji 17 FreeMono 13
   `/ossssso+/:-        -:/+osssso+-     CPU: AMD Ryzen 7 9800X3D (16) @ 5.307GHz
  `+sso+:-`                 `.-/+oso:    GPU: AMD ATI Radeon RX 7800 XT
 `++:.                           `-/+/   GPU: AMD ATI Radeon Graphics
 .`                                 `/   Memory: 61830MiB
Is it this computer? If so that's pretty important information for this thread..
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
