I'm having an issue with random reboots, no BSOD, no error, just a reset. It usually happens while playing games, but I'm sure I recall it happening at least once while on the desktop.
Automatic restart has been disabled, still no messages.
Temps have been checked for both GPU and CPU, both normal.
PSU has been upgraded, no change.
Overnight memtest came back as normal.
Any ideas where to go next?
Specs below...
ASUS TUF GAMING B460-PLUS (LGA1200)
Asus ROG Strix 1200W Platinum PSU
Intel Core i9 10900K (No OC)
32GB RAM
ASUS NVIDIA GeForce RTX 4070
931GB SanDisk SDSSDA-1T00 (SATA (SSD)
931GB Samsung SSD 860 EVO 1TB (SATA (SSD)
1863GB Samsung SSD 970 EVO Plus 2TB (Unknown (SSD)
Focusrite USB Audio
CPU Intel Core i9 10900KF | Motherboard ASUS TUF GAMING B460-PLUS | RAM Corsair Vengeance RGB PRO Black 32GB 3200MHz DDR4 | GPU ASUS Dual GeForce RTX 4070 OC Edition 12GB
Case Corsair iCUE 5000X RGB | Boot Drive Samsung 970 EVO PLUS 2TB M.2 | PSU Asus ROG Strix 1200W Platinum | Display ASUS ROG Swift OLED PG42UQ
CPU Cooler Corsair H100i ELITE CAPELLIX RGB AIO | Keyboard Corsair K100 RGB | Mouse Logitech G900 | Audio Focusrite Scarlett 2i2 & 2xYamaha HS7 | OS Windows 11 Pro
https://linustechtips.com/topic/1626834-hard-reboots-help/
Specs below...
32GB RAM
Focusrite USB Audio
Check event viewer -> system. Filter for critical errors. Check the error code. If its error 41 (63) then its most likely related to ram instability. Is ram at auto settings? Did it work at some point? Check if ram sticks is in slot a2 and b2. Try at auto settings, first. If it still doesn't work, either swap the ram kit or tweak memory controller voltage (vccio and vccsa). If you get a new ram kit I can recommend getting a 2933 kit.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1626834-hard-reboots-help/#findComment-16827682
No critical errors other than the ones related to the unexpected shutdown.
This has only been happening for the past few months, maybe around the time I upgraded the GPU, but I can't be certain of that.
https://linustechtips.com/topic/1626834-hard-reboots-help/#findComment-16827718
Exactly what error 41 is
https://learn.microsoft.com/en-us/answers/questions/3802067/kernel-power-event-id-41-task-category-(63)
Yes you could try setting ram to auto if you changed that from default. Or get another ram kit and test that. You already ruled out the other possibility, a faulty PSU.
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1626834-hard-reboots-help/#findComment-16827722
I've changed RAM from AUTO to XMP1. We'll see what happens.
https://linustechtips.com/topic/1626834-hard-reboots-help/#findComment-16827841
Event ID 41 is just Unexpected Shutdown. You get this from any crash, freeze, BSOD, power loss, holding the power button or pressing the reset button. It has no diagnostic value unless you didn't know it shut down unexpectedly. The Details tab has some useful information, but just the event ID has nothing.
@NeoDude Screenshot the Details tab of the a few of the Kernel-Power events.
https://linustechtips.com/topic/1626834-hard-reboots-help/#findComment-16827847
Yes it doesn't say much, but since we have nothing else and have ruled out some stuff, we're on the right path. Usually kernel event 41 (63) is simply this:
How to Fix Kernel Power Error 41 in Windows 11/10?
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1626834-hard-reboots-help/#findComment-16828033
The Details tab has the error data if there is any. If there isn't any, it's likely power related.
https://linustechtips.com/topic/1626834-hard-reboots-help/#findComment-16828388
As stated, a computer that reboots with no BSOD is either overheating or there is an issue with the PSU.
Download HW Monitor and view the Temperatures, especially after a reboot. You can also view the voltages for any anomalies.
https://www.cpuid.com/softwares/hwmonitor.html
Please click the "Thumbs Up" on any volunteer's post to thank them if they helped .(lower left, just to the right of My Computer )
https://linustechtips.com/topic/1626834-hard-reboots-help/#findComment-16828554
Or in some cases ram or memory controller related. Hwinfo64 is a much better program imo.
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1626834-hard-reboots-help/#findComment-16828578
Yes but not PSU related, because it was changed.
@NeoDudeWill report back with the results
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1626834-hard-reboots-help/#findComment-16828579
Just happened again while playing Re-entry. As stated before, temps are all normal and PSU has been swapped....
https://linustechtips.com/topic/1626834-hard-reboots-help/#findComment-16829800
Not sure if it's related at all, but I carried out a SFC Scan, which found and repaired a corrupt C:\WINDOWS\System32\drivers\bthmodem.sys
https://linustechtips.com/topic/1626834-hard-reboots-help/#findComment-16829817
