I bought a rx5700xt for $50 in non-working condition after a power outage and she worked for around 6 months flawlessly until yesterday, while I was playing forza (horizon 5, gpu util ~95% cpu util~30% the system hard restarted and woke up with only one monitor on and the second in a weird aspect ratio and horrible resolution. I had done every driver and update applicable to my machine, dusted, cleaned and repasted the card to no avail. Windows doesn't detect displays and shows as my computer not having a gpu?On top of all of that I had some insane artifacting happen in the bios and a symptom where anytime I'd move the mouse the screen would go black, the fix was to plug the first monitor into the on board graphics?? Hardware part list https://pcpartpicker.com/user/cjyeetgod/saved/#view=qzVYQ7
https://linustechtips.com/topic/1626097-rx-5700xt-extremely-weird-issues/
Try the classic method of putting it in an oven:
https://www.overclockers.com/the-oven-trick-repairing-your-broken-video-card-with-an-oven/
If that doesn't work unless you plan to get into electronic repairs the card is toast sort to speak.
