hi so this is the situation i am in, currently deciding which hardware i am going to buy to build my first pc, stuck on deciding on the psu, my main options are the corsair rm850w or the rm1000w, the 850w is about £130 and the 1000 is about £150 but goes up to £170 when the places that stock it at £150 run out :
expected specs:
9800x3d
9070 xt
32gb ram
msi MAG X870 TOMAHAWK or MSI MPG B850 EDGE TI
so the 850w has 3 pcie connectors and the 1000w has 4 connectors, the motherboard has an extra connector for pcie so not sure if to connect that and if i have the 850w one i will only have 2 connectors left for the gpu and some of them need 3 pcie's and i dont want to limit myself to only ones that need 2 connectors, also some of the 9070 xt card say different minimum requirements for example the powercolor red devil i think says 900w so not sure if the 850w psu is suitable, so i would prefer to get the 850w to save some money and its easier to get hold of as the 1000w gets going out of stock at the lowest price but not sure about the minimum requirements and the need for more pcie connectors. hope someone can help me sort this out.thanks.
https://linustechtips.com/topic/1623568-gpu-power-help/
I see a max consumption of your system around 130+300=430W so you don't need a 1000W power supply.
The mobo pcie power connector is mostly for the birds as far as I know.
Edited by leclod
If you don't quote us, we won't know you answered
https://linustechtips.com/topic/1623568-gpu-power-help/#findComment-16804935
currently choosing my parts for my first pc build and had decided on either the corsair rm850x or the corsair rm1000x, would have preferred to go for the 850w to save some money but it only has the 3 pcies and i wanted 4 pcies but the 1000w one had 4 pcies, anyway the 1000w one keeps going out of stock at the cheaper price of £150 so left with the next in stock price of £180 while the 850w is about £130, also some of the 9070 xt card have a minimal requirement of 900w(powercolor red devil).Now i have come across the be quiet! Pure Power 13 M 850 W and its about £110-£120 and has good reviews and has 4 pcies but the 4 pcies come on just 2 cables so they are daisy chained and not sure about how safe as i have heard before to make sure to connect 1 pcie per cable for safety.anybody got any experience or advice about this bequiet psu.
https://linustechtips.com/topic/1623568-gpu-power-help/#findComment-16805718
Daisy chain is fine.  They wouldn't include them with their PSU if not.
There's no demonstrable differences in performance or longevity one way or the other.
Why do you want 4 pcie?
Either way, you can't go wrong with any of the picks.
A 900w requirement is conservative, they don't know the CPU you're using so they err on a 14900k over locked to be safe.
As above, you'll be drawing 400-500 watts max.
At some point just buy a damn PSU and build your machine.  All you listed are perfectly fine
Not sure what will convince YOU of this tho. 👍
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1623568-gpu-power-help/#findComment-16805805
thanks for the replies, need 4x pcie because i need 3 for 9800xt and need 1 for the pcie extra slot on the motherboard, read lots of things about the extrea pcie slot on the motherboard, many say its useless and ignore it but have also read many comments saying pc wasnt working till they connected it and other comments saying that has there pc crashing but when they connected it fixed it, so want to connect it just in case.
https://linustechtips.com/topic/1623568-gpu-power-help/#findComment-16805894
Are you talking about the CPU power cable?  That's not considered a pcie cable generally.
Send a link to your 9800xt, curious what brand you went with.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1623568-gpu-power-help/#findComment-16805959
hi thanks for the reply, the corsair rm850x comes with 2 EPS 8-pin Connectors for the motherboard and 3 pcies for gpu or other, yeah i made a typing mistake it is the 9070 xt gpu i meant, the 9070 xt will require 2 or 3 pcies depending on brand and model and the msi b850 edge ti has a extra pcie connector on board but i have heard people saying you dont need it and people saying their pc worked better after connecting it.
https://linustechtips.com/topic/1623568-gpu-power-help/#findComment-16806308
