Recently my pc kept crashing while in gaming turns out my GPU was gettin cooked.
I DDU'd my drivers and kept crashing
I Changed my PSU and nothing changed
I update my BIOS and it was more stable but still crashes
I clean reinstalled Windows 11 and update my drivers and DDU'd
I tried to benchmark with FurMark and my monitor flickered I rebooted and the test went fine( 90*C hotspot@ stocks settings ) before I formatted it was getting close to 100 (I think it was because my undervolt settings).
My CPU temps are running fine
EDIT2: My PC just randomly crashed after 10 min of gameplay and a 30 min of browsing
EDIT3: Played for a good 2/3h of death stranding and everything was fine, I let my game on pause and the pc just restarted...
https://linustechtips.com/topic/1623212-error-kernel-power-41-63/
In itself a Kernel Power 41 error simply means that your computer shut down unexpectedly. You would also get that error if you experience a black out or if you trip on your power cord.
53 minutes ago, Mumintroll said:
You have a WHEA error there, can you post a screenshot of what it says?
Yes, this one is more relevant and usually associated with a hardware problem.
54 minutes ago, Mumintroll said:
Can you also write full system specifications?
I totally agree. It makes the job easier for both you and us.
- Provider
      [ Name] nvlddmkm
- EventID 153
      [ Qualifiers] 0
  Version 0
  Level 2
  Task 0
  Opcode 0
  Keywords 0x80000000000000
- TimeCreated
      [ SystemTime] 2025-09-20T18:58:10.2337389Z
  EventRecordID 5177
  Correlation
- Execution
      [ ProcessID] 4
      [ ThreadID] 7908
  Channel System
  Computer ZHANPC17092025
  Security
- EventData
      \Device\0000007a
      Restarting TDR occurred on GPUID:2700
      00000000020030000000000099000000000000000000000000000000000000000000000000000000
Binary data:
In Words
0000: 00000000 00300002 00000000 00000099
0010: 00000000 00000000 00000000 00000000
0020: 00000000 00000000
In Bytes
0000: 00 00 00 00 02 00 30 00 ......0.
0008: 00 00 00 00 99 00 00 00 .......
0010: 00 00 00 00 00 00 00 00 ........
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 00 00 00 00 00 00 00 ........
Most recent error (monitors turns black and restarted itself)
14 hours ago, ZhannaH said:
R5 5600X
MSI X470 Gaming Pro with the latest BIOS available
RTX 3070 Asus Rog Strix
8x2 GB DDR4 corsair vengeance @ 2133Mhz
Corsair RM 750e
1TB HDD Western Digital Blue
You do not happen to have a cheap chinese LCD to display temps etc? I got similar WHEA and kernel 41 cause of one. Worked fine for months, then i got 2 displays and it made my PC crash. I have unplugged it for now, untill i get around to make some custom drivers for it. Cause those it came with sucks.
i9-12900KF | ASUS Strix Z690-A D4 | 64 GB DDR4 13-14-14-28 | XFX 7900 XTX | 990 Pro 4 TB + P3 4 TB + 970 Evo Plus 500 GB | 870 QVO 4 TB + WD Blue 1 TB + Crucial 256 GB | Corsair 7000X Mesh | HX1000 Platinum | H150i Elite 360 | Samsung G8 OLED 32" + ASUS ROG Swift 34" Ultrawide
nvlddmkm id 153
You have already checked the Nvidia drivers and even reinstalled Windows.
Have you tried older drivers? Go back to 566.36 and try them. (Also change the setting so Windows update doesn't update drivers.)
But since you're having WHEA errors too I suspect hardware error.
Do you have a spare GPU?
I usually edit my posts.
Refresh the page before answering to my post.
4 hours ago, Mumintroll said:
nvlddmkm id 153
I tried to rollback 2 driver for Nvidia, ATM I don't have any spare GPUs 😕
I've got an old LCD display from Samsung and an old FHD 144hz curve display from Samsung,
you're suggesting unplugging the old display?
You can try and see if it solves your problem. Cause then you will know what the problem is atleast if its magically fixed after plugging the old one out.
Or maybe you can try forcing Vsync on in windows, and then use Vsync option off in games to run main screen at 144hz in games. Happens windows does not like when two displays got different refreshrates,
just tried unplugging the other to no avail, now it crashes as soon as I enter Windows
Can you ask a friend that can come over with a GPU to test, or if you can take your 3070 to your friend's pc to test?
On 9/26/2025 at 6:37 AM, Sawa Takahashi said:
Did you download the driver from the Asus website ? They are tweaked to better fit Asus GPUs and they are less buggy.
I dont think its a driver issued because when I, fresh installed win It kept rebooting my PC in the startup of windows
You mention undervolting in your initial post.    Did you turn it off or apply new settings after you reinstall windows?
Also could be your PSU, if you have had the system for 5+ years if could be starting to go, have you dusted out the PSU?
I used MSI afterburne to Undervolt and I just swapped my PSU as I said in the first post,
My friend tried his rtx 3070 and we encountered the samme issue, he tried my asus gpu on his PC and everything worked fine, I there's a issue with my CPU/MOBO
Just did that I think there's something wrong with my Motherboard or CPU.
I guess it's time for an Upgrade
