I want to get a small watercooling loop for my gpu and cpu but i dont know what to get?
I have 2 fans already for it.
Nvidia GTX 660 - EVGA
AMD FX 8320 AM3+ Socket
Corsair Carbide 500r Case
my budget is $180. or £100
And anyone wandering... I am going to upgrade in the near future.
https://linustechtips.com/topic/162293-watercooling-first/
do they even make water blocks for 660s?
edit: they do wow
another edit: i should probablly actually contribute to this thread so i would recommend you get a higher end system before you get a loop ($180 inst enough anyway)
"Anything that makes a console more like a PC, makes it better"
-Linus Sebastian
https://linustechtips.com/topic/162293-watercooling-first/#findComment-2160323
Sadly you won't be able to water cool a CPU and GPU for that money unless you buy those cheap no name kit on ebay. You can get a good to great kit for just the CPU though. The GPU may have a full cover block if not you can buy a universal block for it but if you do not have a fan to cool the RAM and vrms then your card may die.
I suggest you check you GPU's make and model on EKWB.com and see if there is a full cover block for your GPU before you make a decision or purchases.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/162293-watercooling-first/#findComment-2162553
