Hello Gamers. I've got the Corsair K70 Core TKL (the one that came with the WAN backpack some weeks ago) and I need a little help disassembling it. I've located and taken out all the top facing screws underneath the keys but after that the chassis still seems held down. I've tried searching YouTube and Reddit to no avail. Even changing search engines reveals nothing and, of course, Corsairs own product page was of no help. Does anybody have any experience disassembling this keyboard or any other ideas? Thanks in advance.
https://linustechtips.com/topic/1622789-help-disassembling-k70-core-tkl/
I’ve taken apart a couple of Corsair boards before not this exact one, and usually there are hidden clips or screws under the rubber feet or under the warranty sticker. Even after removing all visible screws, the top and bottom shells can feel stuck because of those plastic tabs.
Try gently prying around the edges with a plastic spudger or guitar pick, starting from one corner. Don’t use too much force, Corsair cases are tight but they will separate once you release the hidden clips. Also double-check under the spacebar row or near the usb cable entry, since Corsair sometimes hides screws there.
