amd Build for another friend!
Solved by RONOTHAN##,
https://uk.pcpartpicker.com/list/nFnX6Q
This would be my picks. A better motherboard, better RAM, more storage, and as the motherboard picked has on-board WiFi there isn't a need for the WiFi adapters. The 9060 XT is a little bit slower than the 5060 Ti (5% on average), but it's also £80 cheaper that allows for those other quality of life improvements and to be under budget.
