12vhpwr Cable safe?
By
Sixteenthirty
in Graphics Cards
in Graphics Cards
Solved by FilipposTechGR,
Looks fine, the bends are gentle and not right at the connector, which is the critical part. The danger comes if you sharply bend or put stress within 3cm of the GPU plug. As long as the connector is fully seated and the bends are smooth like in your pic, it’s safe.
5
1
toxic_worper ·
7
1
voltigeurramon ·
Posted in Troubleshooting2 -
1
1
