Budget (including currency): n/a
Country: uk
Games, programs or workloads that it will be used for: cyberpunk,football manager, multitasking while playing games,
potential build
AMD 9800x3d 9070 xt corsair rm1000x 64gb ram
Hi doing my first build and need some advice, i want 2 m.2 drives, thinking 1tb for boot and apps and then 2tb for games etc, budget is no more than £200 in total.
https://linustechtips.com/topic/1622230-new-build-help/
hi thanks for the reply, total storage budget is at most £200, resolution will be 1440p or 4k really depends on the gpu and the monitor(yet to buy),will use for games and multitasking(thats the reason for the 64gb ram),£200 budget is for the hard drives.
https://linustechtips.com/topic/1622230-new-build-help/#findComment-16796185
