I recently bought an ASUS TUF gaming B650-E with a Ryzen 7 9800x3d bundle at Microcenter. After building the pc I tried to boot it up but got a black screen. Power is being ran through the system and everything seems to have powered I replugged and reseated everything I went ahead and updated to the latest bios version but nothing has changed.
https://linustechtips.com/topic/1619051-help-please/
Does the system have a GPU and did you plug the monitor in the GPU? Your CPU doesn't have onboard video, so you must use a GPU. To get it running and checking everything, a simple GT710 will do, but you won't be gaming on that one for sure.
"You don't need eyes to see, you need vision"
(Faithless, 'Reverence' from the 1996 Reverence album)
https://linustechtips.com/topic/1619051-help-please/#findComment-16775178
The processor has an iGPU:
https://www.amd.com/en/products/processors/desktops/ryzen/9000-series/amd-ryzen-7-9800x3d.html
It’s possible that memory training is taking place (black screen). Let it run for a few minutes, then turn the system off and on again.
If a particular comment or answer solved your problem, please mark it as the solution. If you found something helpful or useful, consider giving it a like as well, it helps others too. 😉
https://linustechtips.com/topic/1619051-help-please/#findComment-16775181
Op to accentuate this it legit can take close to 10 minutes sometimes the first time had that recentlt with a 7500f b650 from asrock where it took 9 minutes to get into first bios training just some regular gskill ram 😛
https://linustechtips.com/topic/1619051-help-please/#findComment-16775206
Yeah, I usually leave it on like that for a long time, and I always go for a smoke while it's on, because watching a black screen is pretty frustrating 😄
https://linustechtips.com/topic/1619051-help-please/#findComment-16775211
