Hi Guys, I've just bought a gaming pc. Here are the specs
RAM: 16 GB / Storage: 1 TB SSD
Graphics: NVIDIA GeForce RTX 3050 8 GB
Now it's not the best but it's not going to be doing so much only using for streaming. It has 1 HDMI & 2 display ports on the motherboard, well guessing it's on the MB being that they screw in right to where the wifi antennas would go. Download the graphics card software as it's a new graphics card/system. Just wanted to check. How can I set my pc to use the graphics card inputs, another HDMI and two DP? Or better still can you install it to give me two HDMI’s and 4 DP’s at the moment when plugging a monitor into the top HDMI or DP’s I'm getting no signal
https://linustechtips.com/topic/1619023-need-some-advice-please-help/
So just to make sure I understand correctly, you're wanting to get a display signal out of both the graphics card outputs and the motherboard outputs, right?
In that case - what CPU do you have?
"TV Gaming" PC: Ryzen 5 5600 :: 32GB DDR4-3200 :: RTX 2070 Super :: 500GB PCIe 3.0 SSD :: 1.5TB of SATA SSDs :: Windows 11
"Desk Gaming" PC: i5-4690K :: 16GB DDR3-1600 :: RX 560D 4GB :: 500GB SATA SSD :: Linux Mint 22
Office PC: Dell Pro 14 :: Ultra 7 268V :: 32GB DDR5-8533 :: 512GB PCIe 4.0 NVMe :: 6TB HDD :: Windows 11
Laptop: Dell Latitude 15.6" :: i5-4200U :: 8GB DDR3-1600 :: 500GB SATA SSD :: Linux Mint 22
Primary NAS: i5-7500 :: 16GB DDR4-2133 :: 250GB SSD :: 8TB HDD :: TrueNAS Scale 24.10
Web Server/Backup NAS: Raspberry Pi 4 Model B :: 2GB RAM :: 64GB microSD card :: 8TB HDD :: Raspberry Pi OS
Other tech stuff: iPad Pro M4 13" :: Samsung Galaxy A15 4GB :: 2022 Kindle Fire HD 7 :: PS4 Slim w/ 1TB SSD :: OG Nintendo Switch
Your display needs to be plugged into the graphics cards ports, not the motherboards, typically when a graphics card is installed in a computer the iGPU ports(on the motherboard) are disabled. If you want to use both and your CPU has an iGPU you will need to enable the iGPU in Windows and also the Bios of your motherboard. To add, you did not list in your specs what processor you have, some processors don't have iGPUs at all so it's possible this is also the case with your system. Please list your CPU and we can let you know if what you want to do is even possible.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
