i have a 7600x as my cpu and it hovers around 50c and on occasion clocks up to around 60-10 which is what it reaches while gaming, are these temps normal. also my thermal paste was of blue tack consistency when i put it on which is why im extra curious of if this is normal temps.
https://linustechtips.com/topic/1619002-thermal-questions/
Those temperatures are great for Ryzen 7000 series X CPUs. They are designed to be thermally limited and have a thick IHS, so temps of 95C are normal.
I'm guessing you've got a decent cooler then, like a dual-tower or 240mm AIO.
https://linustechtips.com/topic/1619002-thermal-questions/#findComment-16774854
Thats a bit high for idle, but very good for being under load.
You could use some fine tuning on your fan control, it would seem. But don't get me wrong, that isn't necessary at all. You are operating within perfectly healthy temperatures
I sell teeth and teeth accessories 🦷
https://linustechtips.com/topic/1619002-thermal-questions/#findComment-16774855
Without knowing how its cooled, the case airflow setup and the ambient temps, hard to say. It sounds fine for a stock, non-undervolted setup on a 120mm single tower cooler but again, all depends on many factors.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1619002-thermal-questions/#findComment-16774856
the idle is completely fine and i know that. the idle wasn't what i was curious about
https://linustechtips.com/topic/1619002-thermal-questions/#findComment-16774857
im using the Thermalright Phantom Spirit 120 SE which came with some tacky thermal paste so i dont know if it was expired but i haven't had issues using it
https://linustechtips.com/topic/1619002-thermal-questions/#findComment-16774864
i cant reach temps of 95 i flashed a newer bios and it made it thermal throttle before that but that hasn't caused any issues. and i am using a duel tower, im using Thermalright Phantom Spirit 120 SE
https://linustechtips.com/topic/1619002-thermal-questions/#findComment-16774868
If you know the max temp of your CPU, you'll know 60c is great.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1619002-thermal-questions/#findComment-16774869
