help building pc
Solved by Hinjima,
3 minutes ago, Taku05 said:ok thank you , whats your opinion on the peripherals? n about memory so even if the board say it supports more than 6000mhz for memory it will give me problems?
The sweetspot as mentioned is 6000Mhz CL30 as this is what we know will 99.99% of the time work at the rated speed.
Going above this can cause compatability issues or stability issues. There is little to no benefits in going above this RAM speed.
The board will support faster RAM but getting it to run stable is difficult and you have to manually tweak settings to get it to run in 1:1 with the CPU's infinity fabric etc etc.
If you go above 6000Mhz you are likely to run into some problems, the higher you go the more potential problems.
