help building pc
Go to solution Solved by Hinjima,
3 minutes ago, Taku05 said:
ok thank you , whats your opinion on the peripherals? n about memory so even if the board say it supports more than 6000mhz for memory it will give me problems?
The sweetspot as mentioned is 6000Mhz CL30 as this is what we know will 99.99% of the time work at the rated speed.
Going above this can cause compatability issues or stability issues.  There is little to no benefits in going above this RAM speed.
The board will support faster RAM but getting it to run stable is difficult and you have to manually tweak settings to get it to run in 1:1 with the CPU's infinity fabric etc etc.
If you go above 6000Mhz you are likely to run into some problems, the higher you go the more potential problems.
2 minutes ago, Taku05 said:
any opinion on the perpherals ? but ye thanks hopefully i dont bend a cpu pin or something , coming from an xbx series S its a big upgrade for me
You'll be fine 🙂 Just watch some build guides and take it slow.
If you need help I can be around on Discord to guide you if you get stuck.
I am not a peripheral guy, I basically only deal in PC hardware. So I have no opinions on the peripherals you picked out.
I do own the Logitech Pro X 2 Headset and its very comfortable and the sound is good 🙂
1 minute ago, Hinjima said:
That is a decent model of the 5070 Ti, be aware that the ''Gigabyte GeForce RTX 5070 Ti EAGLE OC ICE'' is a SFF ( Small Form Factor ) GPU so its a bit smaller than your average GPU and this can affect cooling and noise levels.
The GPU will still perform identical to other 5070 Ti's but it might be a bit louder than beefier cards like the Gigabyte RTX 5070 Ti AERO for example.
The RAM is good 🙂
ok thank you
thank you. very much
2 hours ago, Hinjima said:
The AIO comes with good enough paste that will last years...
Recommending any paste at all is just a waste of money.
A second tube of paste allows you a lot of flexibility to tear down the system for cleaning / upgrading / troubleshooting, and can be great for multiple systems you might have, such as dad's PC or gramma's slow laptop. It's not necessary by any means, but far from a "waste of money".
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
22 hours ago, Taku05 said:
ok thank you
im about to order the stuff and i see the 7900 xtx being sold for R14 999 which is about 800 usd lol since it was amd s most powerful card im tempterd or is the 5070 ti better than it , i was literally about to order before i saw the special
7900xtx would be a pretty awful buy at this point in 2025. 5070Ti offers near enough the same raw raster performance but gives you access to Nvidia's current generation of software features. You'd need a 9070xt to get FSR4, 7900xtx is locked to the old FSR3.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
cool tnx
