Help finding a small GPU
Go to solution Solved by Manny Calavera,
MSI has super small 760 version
also, 750ti is tiny, gainward, evga, gigabyte, ... have small variants
Hello! This is my first post, please be gentle!  ^_^
I'm having some trouble finding a GPU that would fit my prebuilt HP, it's a tiny slimline
I've got approximately 18 cm in length, 8.5 cm in height and 5.5 cm in width, which would be
7 inches length, 3.3 inches in height and 2 inches in widht
My budget is about 300-400 dollars, I live in Mexico, but I may be able to import from Amazon
Thanks in advance!
Using Tapatalk
https://linustechtips.com/topic/161743-help-finding-a-small-gpu/
