Budget Around: 50 000 SEK. / 6 000 USD. / 5 000 EUR.
Games, programs or workloads that it will be used for: AAA-games + CS2
RTX 5090+9800x3D is already decided.
(I got a BenQ ZOWIE XL2586X for CS2 that i would like to not bottleneck. Monitor for AAA-games not yet decided. So any suggestions would be appreciated here too.)
TL;DR: I need your opinions on the build, and whether or not you would change or add anything!
https://se.pcpartpicker.com/list/TwF2MC
Thank you for your support.
BR
OwPe
https://linustechtips.com/topic/1616951-50909800x3d-build-help/
Not bad but you could cut down costs even further with practically no downsides if not slight upgrades like the PSU
https://pcpartpicker.com/list/TwF2MC
Also you used euros yet the list is in USD
Can we get a specific country cause PCPP supports a number of European countries
I edit my posts for so if you saw a typo.... no you didn't, you are just crazy
https://linustechtips.com/topic/1616951-50909800x3d-build-help/#findComment-16761089
7 minutes ago, OwPe said:
Budget: 5 000 EUR.
https://pcpartpicker.com/list/WmBVQd
BR
OwPe
The link takes us to USA prices / components. What country are you located?
https://linustechtips.com/topic/1616951-50909800x3d-build-help/#findComment-16761090
My bad...
I have now changed the currency to SEK since i live in Sweden.
14 hours ago, WereCat said:
I would change the monitor unless you already have it, TN panel with this system is a waste. There are 500Hz OLEDs being released right now for roughly the same price.
Interesting! i'll keep a look out.
I bought that monitor last year, with a discount of almost 50% so i could not let it pass ^^
Im positive that i can get atleast as much as i spent on it if i would have sold it today. If not more!'
BR
OwPe
https://linustechtips.com/topic/1616951-50909800x3d-build-help/#findComment-16761507
2 hours ago, OwPe said:
My bad...
BR
OwPe
Alternative case:
https://www.proshop.se/Chassi/Lian-Li-Lancool-217-Black-Chassi-Miditower-Svart/3371767
https://lian-li.com/product/lancool-217/
https://se.pcpartpicker.com/product/pMRwrH/antec-flux-atx-mid-tower-case-0-761345-10133-2
https://www.antec.com/product/case/flux
https://se.pcpartpicker.com/product/j2kqqs/antec-flux-se-atx-mid-tower-case-0-761345-10177-6
https://www.antec.com/product/case/flux-se
https://linustechtips.com/topic/1616951-50909800x3d-build-help/#findComment-16761549
