NEED HELP
Go to solution Solved by KidKid,
14 minutes ago, LOL-jpg said:
currently using an asus rog x670ei for my 7800X3D but I cant increase its frequency to 5.05, it stays at 4.7 . Anyways to increase that?
PSU:seasonic core 780w
AIO:thermalright 240
RAM:gskill 16*2 6000 CL36
only thermal limits are increased to 90C and PBO enabled in BIOS
Make sure you're only stressing out one CPU core. The all-core boost is supposed to be 4.7Ghz, while the single core boost is over 5Ghz.
https://linustechtips.com/topic/1615943-need-help/
Do you have reason to believe this is possible? What methods are you using now? Are those all-core numbers? If you want to push clocks, swap in a 9800x3D.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1615943-need-help/#findComment-16753678
Did you do PBO +200 and CO -30 (or other negative)?
Mine reaches 5.05GHz.  Look in HWINfo64, not Task Manager.
Clarity:
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1615943-need-help/#findComment-16753685
What software are you using for the clocks? Single core or all core?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1615943-need-help/#findComment-16753688
https://linustechtips.com/topic/1615943-need-help/#findComment-16753694
For the 7800X3D, 5GHz is the max boost, which is only going to be achieved during lightly threaded workloads. All-core won't hit 5GHz.
On 7000 series X3D chips, overclocking is locked down. You are allowed to use Curve Optimizer to undervolt it, and you can enable PBO, but you cannot change its boost behavior directly. This is because the 3D V-Cache is stacked on top, so functionally thermally insulates the cores, which makes traditional overclocking dangerous - at least, according to AMD. So AMD locked down overclocking.
If you want more consistent clocks, you can use Curve Optimizer to give it an undervolt, which should help with thermals and thus improve the boosting characteristics (since Ryzen boosts higher at lower temperatures). That's your best bet with a 7800X3D.
The 9000 series X3D CPUs are the only ones that are truly unlocked for overclocking.
https://linustechtips.com/topic/1615943-need-help/#findComment-16753695
