Current Setup: i5-6500
16GB 2133MHZ
2 Samsung 870 Evo 250GB
GTX 1050TI Nvidia
Gigabyte B150 HD3P
SeaSonic Electronics S12II Series SS-520GB 520W 80 Plus Bronze Power Supply (taken from google but this is my psu)
I want to upgrade to a RTX 2060, 1660TI or a RX 580, what is the smartest option? I would prefer the 2060 in terms of performance but not sure if its smart, the 2060 is around 120-130Euros the 1660 ti around 110-120, the rx580 is real cheap for around 60-80, what would be the best to choose?
https://i.imgur.com/Ttomutb.png
https://i.imgur.com/5wfWuKd.png
https://linustechtips.com/topic/1615680-upgrade-help/
16GB 2133MHZ
GTX 1050TI Nvidia
Gigabyte B150 HD3P
Looking at some game benchmarks in 1080p the 2060 will be bottlenecked by ur old i5 so i would go with one of the cheaper options or upgrade ur cpu in the near future aswell
https://linustechtips.com/topic/1615680-upgrade-help/#findComment-16752067
16GB 2133MHZ
GTX 1050TI Nvidia
Gigabyte B150 HD3P
I would get the 2060, and then upgrade your cpu later
https://linustechtips.com/topic/1615680-upgrade-help/#findComment-16752090
16GB 2133MHZ
GTX 1050TI Nvidia
Gigabyte B150 HD3P
2060. The 2060 has features that the other two GPUs don't.
https://linustechtips.com/topic/1615680-upgrade-help/#findComment-16752157
