Equalizer issues on Mint
Solved by C2dan88,
13 hours ago, yogurt245 said:I'm using headphone connected straight into my motherboards line out jack.
Try using EasyEffects (should be found in Synaptic Package Mander or install via apt) with perfect eq preset shared by JackHack*
https://github.com/JackHack96/EasyEffects-Presets
(*Run the install.sh command for easy install of the preferred preset.)
To load, open EasyEffects, select Presets tab and click Load button next to installed preset.
Click Pipewire tab and ensure EasyEffects is using the correct output device.
