Intake/Exaust Layout Help
7 minutes ago, Jacobplayz said:Hello, I am building a new computer and I was having a bit of trouble deciding what to do with my fan and AIO layout in my case. Currently, I have 2x160mm fans in the front, and 1x140mm fan in the back. I am looking to put a 360mm AIO at the top of the computer, but my only problem is I'm not sure which direction i should put my fans for the AIO. I've been told all my life by numerous people that i should keep positive pressure in my build, but setting the AIO to intake would only leave 1 exhaust fan and I'm not sure if that will be nearly enough. Putting the AIO to exhaust would not have positive pressure. I considered putting fans at the bottom of the case, as it allows for that, but I read somewhere that those fans should always be intake to flow with the PSU. Can somebody give any suggestions?
Case: Lian Li Lancool 216AIO: Cooler Master MasterLiquid 360L Core ARGB
You could always have the rear fan that is currently exhaust, as intake! It will give fresh air directly to the AIO on top
It would also give slight positive pressure with the 2x160mm front fans too.
I mean damn.. I got 2x180mm intake at the front, I have 3x140mm intake at the bottom and ONE 140mm exhaust at the rear.. is enough
The warm air will escape from other open spots in the case with positive pressure.
