Hi guys I need some help and advice I'm upgrade from am4 to am5 we're my cx600m that's 11 years old fried and went up in smoke last Friday so my grandparents agreed to help me build a new one. In my old build I also had a Intel arc a770 but the PSU wasn't sending it the correct voltage from the 12v rail. Under load it was reaching temps of 89c to 90c and my GPU voltage was only 0.85volts.
Parts list:
2500x Corsair case
9800x3d
32GB of g skill ram
Msi b650m project zero motherboard
Xfx rx9070xt
Corsair rm850e
My total build price is $1,952.27
Also I loved my Intel arc a770 until my PSU gave it the issues could I go with the Intel ARC B580 until the B770 comes out or stick with the rx9070xt or get a Intel arc a770 from eBay because I found one brand new. I also have a oled 1440p 27inch LG 240hertz monitor. If that helps with GPU guidance and advice. Also thanks in advance.
Edited by cmo30
https://linustechtips.com/topic/1614496-pc-build-advice/
7 minutes ago, Grady_Smith said:
What is your budget?
I really didn't have a budget cause my granddad just told me to get a parts list together he really didn't say a budget I would say probably $2,000 under if possible I'm trying to save as much money on this new one but still get great performance that way I'll have a PC that will last me for a good while.
https://linustechtips.com/topic/1614496-pc-build-advice/#findComment-16744910
Here's a few cost cutters ... add storage.
PCPartPicker Part List
CPU: *AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($384.59 @ Amazon)
CPU Cooler: *ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler  ($29.99 @ Amazon)
Motherboard: *Gigabyte B850 GAMING X WIFI6E ATX AM5 Motherboard  ($179.99 @ Amazon)
Memory: *TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($89.99 @ Newegg)
Video Card: *Sapphire PULSE Radeon RX 9070 XT 16 GB Video Card  ($799.99 @ Newegg)
Case: *Montech AIR 903 BASE ATX Mid Tower Case  ($64.98 @ Newegg)
Power Supply: *Super Flower Zillion FG 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Newegg Sellers)
Total: $1659.52
Generated by PCPartPicker 2025-06-08 16:04 EDT-0400
https://linustechtips.com/topic/1614496-pc-build-advice/#findComment-16744913
Total: $1659.52
Awesome thank you for your help and advice would the Intel ARC B580 be a good GPU for my 1440p monitor we're my Intel arc a770 craped out on me or would the rx9070xt be a better fit I just really liked the Intel ARC GPU after having one myself since 2023.
https://linustechtips.com/topic/1614496-pc-build-advice/#findComment-16744923
https://www.techpowerup.com/review/sapphire-radeon-rx-9070-xt-pulse/32.html
https://linustechtips.com/topic/1614496-pc-build-advice/#findComment-16744924
