Need help selecting components (First time builder)
Go to solution Solved by Why_Me,
Look at a 1440 monitor in regards to the 5070 Ti.  Add your preferred AIO.
PCPartPicker Part List
CPU: *AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($384.95 @ Amazon)
Motherboard: *Asus TUF GAMING X870-PLUS WIFI ATX AM5 Motherboard  ($256.52 @ Amazon)
Storage: *Samsung 990 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($169.99 @ Abt)
Power Supply: *MSI MPG A850GS PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($139.99 @ Newegg)
Total: $951.45
Generated by PCPartPicker 2025-06-06 02:40 EDT-0400
https://www.msi.com/Power-Supply/MPG-A850GS-PCIE5
https://www.asus.com/us/motherboards-components/motherboards/tuf-gaming/tuf-gaming-x870-plus-wifi/
Budget (including currency): 400,000 JMD (around 2500 USD)
Country: Jamaica
Games, programs or workloads that it will be used for: FF16, ZZZ, SF6, Tekken 8, Horizon Forbidden West, Marvel's Spiderman 2, marvel rivals
Existing Parts:
Gpu: Asus TUF 5070 Ti OC
Case: Corsair Frame 4000D ARGB
Ram: Corsair Vengence 32gb(2x16) rgb 6400MHz
Peripherals : I currently already have a 1080p monitor, mouse and headphones, just need a keyboard. I want to find a 4k monitor that is reasonably priced and good value but thats not currently planned for within this budget. I need it to be around 120hz or more.
Upgrading from:
2020 Acer Nitro 5 (16gb ram, RTX 3060, ryzen 5 5600H)
When Im going to buy: I'd prefer to finish this build before the end of the year.
Notes:
I want to get a b850 board or better that isnt going to make my planned 7800x3d buy explode. If I can get a better cpu or motherboard to avoid any issues that would be great. I orginally planned to get an asrock b850 Livemixer due to the cost and specs but im dont want any issues with my CPU. I just want to future proof and not buy any new CPU for a while and preferbly with a fast CPU like the 7800x3d. Either is ok to replace. I was also planning on getting corsair cooling parts to not only remove cable management issues through icue link but fit the corsair aesthetic with the case. I was looking into a 240mm or 360mm AIO from corsair with an LCD screen. Was planning on either 850 or 1000w corsair psu as well. Lastly I plan on storage that is 2TB minimum. I already have a samsung T7 external 2tb SSD I currently use. Main focus of this build is to future proof but be able to game comfortably at 4k max settings in titles listed above at 65 to 70 fps or more. Im willing to compromise on looks for performance. Thanks in advance to any advice or comment given to this post.
Most my parts will be sourced from the US but Canada isnt out of the questions since I got someone to collect a 5070ti for my at bestbuy in Canada.
Total: $951.45
Total: $951.45
Thanks for taking time out to make this
