Help With Mounting
Solved by OhYou_,
im sure they will be equally mad about a large line of 24 holes vs 4 slightly larger holes
I would say use #6 2in long screws in place of the giant bolts that tv mounts usually come with
Be very careful not to overtorque the screws when installing them and be 100% certain you are driving it into the middle of the stud.
four #6 screws properly in the studs and in good condition will be more than enough for a 43in tv and when they come out, it is around the size of hole as a nail.
