The BitFenix Recon and NZXT Sentry Mix 2 seem to be well liked on Newegg and Pcpartpicker. You might want to look at those.
Edit: People seem to like this one by Zalman as well. Your only problem is that you aren't going to find a whole lot of controllers that can do 8 separate fans, if any at all. You would most likely have to use a splitter or plug one or two of your fans into the mobo.
Laptop - Lenovo Y50   Keyboard - Corsair K95 RGB Cherry MX Brown   Mouse - Logitech G502 Proteus Core   Mousepad - Razer Firefly
Please read the LTT Code of Conduct before submitting a post
https://linustechtips.com/topic/161337-fan-controller/#findComment-2148599
  • 4 months later...
Im also looking for a fan controller that doesnt take up a drive bay? I just want my 4 rad fans to be controlled by software? Any suggestions? Im using a Bay res so no Room. https://www.dazmode.com/store/product/poweradjust-3-usb-ultra/ Was thinking this but it looks so complex
https://linustechtips.com/topic/161337-fan-controller/#findComment-3109611
