Rinse and Repeat
Go to solution Solved by Dedayog,
3 minutes ago, forss said:
I've heard that going for an AIO is not the best idea for a first build, is that true? If I were to get one, would it be a good idea? Is it unnessecary with this build? If it is, is it still ok to go with one just for the look if I have the money for it? Not sure how I like how an air cooler looks.
https://newegg.io/5a18e9d
It adds a level of complexity, is all.  Nothing too complicated though.  You install it either on top or on front, on the places the fans go.  It's really easy, but an air cooler is even easier.
Some people just don't like the idea of a liquid in their PC.  I used air cooling for 25 years or so, water for about 10 almost.  I started with water on my 8700K machine I build back when.
In your build it can be useful if you want to let the CPU run a little bit more.  The cooler you can make a chip, the faster it can run.  AMD chips will try to run to 85/90c, so if you can give it more cooling, it can run a higher clock frequency at that same heat level.
Now will this be amazingly noticeable?  No.  But it'll give you a few more frames.  Then again, if you can use that money for a 9700X instead of a 9600X, then I would do that.
Always go for the biggest bang for buck spent.  Once you have the best stuff you can reasonably get, then you try to wring the most out of it, IMO.
For you, stick with a cheaper air cooler and the cheaper CPU.  When you get a 9800X3D, then look at 360mm AIO CPU Coolers.
Budget (including currency): $1,000 USD
Country: United States of America
Games, programs or workloads that it will be used for: 100+ FPS at 1080p or 1440p Gaming, Blender, Coding
- This will be my first ever build, trying to get everything right the first time
- I'm back for a second time after receiving so many great suggestions on my initial build
- I revised the list after some suggestions about the motherboard, and CPU air cooler
- There is no GPU listed as I am purchasing a USED 3060 Ti from a friend
- Any and all suggestions are welcome, I am not set on anything, but I do want to stay AMD (AM5)
Here is the revised list:
https://linustechtips.com/topic/1612727-rinse-and-repeat/
You need to post your revised list.  Tho I am unsure why you need a new thread, since we were making progress in the other.  Just had to ask us to fill out the rest *shrug*.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1612727-rinse-and-repeat/#findComment-16733131
Oh mb, I kinda joined like a day ago, so I am not 100% sure how forums work entirely, thanks for the help though! I just attached the list. I also didn't want to be annoying aobut it but it seems like most people are pretty friendly about giving tips and help.
https://linustechtips.com/topic/1612727-rinse-and-repeat/#findComment-16733136
Mostly it continues the conversation, so people can discuss what's come before.
I like your list for the most part, but I'd get a cheaper SSD and cooler.
Samsung tax is real, there are just as good options for cheaper.
That cooler should be $39.99 max, not sure why it's now $60.   Unless tariffs are hitting that hard, but ten they'd hit the other parts like that too.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1612727-rinse-and-repeat/#findComment-16733322
I plan to upgrade in a year or two, and I want this build to be nice to look at so I wanted the RGB
https://linustechtips.com/topic/1612727-rinse-and-repeat/#findComment-16733469
I am fairly new to this, so I am pretty unfamiliar with good or bad prices when it comes to components, is this SSD something along the lines of what you would recommend?
https://www.newegg.com/team-group-2tb-t-force-g50-nvme-1-4/p/N82E16820985144?Item=N82E16820985144
https://linustechtips.com/topic/1612727-rinse-and-repeat/#findComment-16733472
Yes, it'll perform exactly as the Samsung.  For gaming and general use.
Understood about the RGB cooler.
Looks great then.  Something i'd buy.   You can tweak for minimal price savings, unless someone has other info.
What do you plan on upgrading to?
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1612727-rinse-and-repeat/#findComment-16733485
55 minutes ago, forss said:
Not exactly sure, I wanted to start out small. I would most likely upgrade the CPU and GPU at the same time or close to each other, maybe a 5060 Ti and an R7 7800 X3D, but what would you recommend?
There is no sense in going from 9600X to 7800X3D.  Maybe 9800X3D.  But the 9600X is excellent, so I wouldn't bother upgrading it at all.
The GPU, yes.  The 3060Ti is okay.   Look for a 5070 actually in a year or so, that'll be a much better bump.
All depends on if you're staying at 1080p or going 1440p.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1612727-rinse-and-repeat/#findComment-16733574
https://linustechtips.com/topic/1612727-rinse-and-repeat/#findComment-16733773
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1612727-rinse-and-repeat/#findComment-16733781
