8 pin to 4 pin
AllHopeLost
Go to solution Solved by mkessler9,
Yes its perfectly fine to only plug in half.
Ok so my MOBO has a 4 pin connector. And I want to upgrade my PSU and the one I'm getting is the corsair CXM series CX500M 500W. But the power connect is an 8 pin. Is it ok if I only plugin half of it. Or is there an adapter or something. I know the corsair CX500 has a 4+4 connector. But it's non modular.
Gaming rig- Cpu- Amd 9590, 16gbs of G Skill Ram, Gpu- GTX 760 windforce 3 edition 2gb. A Thermaltake water 2.0 water cooler for my cpu. Keyboard- Thermaltake Posieden , Case- 750D, Mobo Asus 990fx R2.0. 24 inch Dell LED monitor
The Corsair CX500M should have both an 8 pin EPS connector and a 4+4 ATX connector.
