Difference between 2 CPUS
Go to solution Solved by ShadowCaptain,
Building a new pc soon and im thinking whether to get an i5-4670K or i7-4770. Is there any difference between these 2 cpus in terms of performance in gaming? Thinking of getting the i5 as it is cheaper.
The i7 (presumably you would get the 4770k unlocked version so you can OC) is a superior CPU. It can help certain games perform better, as well as video and photo editing, streaming etc
However, if you are working towards a budget and having to sacrifice other components to fit in an i7 then I think the i5 is better value. For most games and tasks it will be perfectly fast and not too differnet from the i7 and the money you save can go towards a better GPU/SSD/Cooler, or whatever else you need for your PC
If you have the money spare, then an i7 is a better investment in my opinion, as you may utilize its extra performance but if its a budget constraint then i5
4670K is an unlocked more easy to overclock cpu, its a quadcore.
4770. is a locked cpu that is very hard to overclock, its a quadcore but can do 8 threads, cause of the HT.
For gaming both are basicly fine.
If you are a diehard watch dog fan + streamer, an i7 could be something to concider. ;)
The i5 is overclockable and will be enough for gaming.
The i7 cannot be overclocked, but has HT, meaning it does have 8 Threads, which might help in certain Games a bit,
but are more important for streaming and other apps that can make use of more than 4 cores/threads.
The i7 might be slightly faster in Games, if you don't overclock. But getting a k-version implies you plan on overclocking, which means it will be better for gaming.
CPU: i7-4770k (LM modded) - MB: GA-Z87X-UD3H - RAM: HyperX, 16GB 1866MHz - GPU: Palit GTX 980Ti Super - Storage: 1TB HDD + 500GB/120GB SSD (850 Evo/840) - Monitor: Predator XB271HU - PSU: 700W BeQuiet 80+ Gold
