Strange Battery behaviour
Go to solution Solved by jaslion,
Battery is doa. It happens ask for a new one.
Recently replaced battery on Alienware R3 99Wh battery from Ifixit.
The battery charges to about 61% and jumps to 100%, and discharges from 44% to 0% in a few second. The battery is brand new, but I did delay a few weeks from installing it, so it was dead and sitting on my self for about a month before I replaced it.
I have done the 'Calibration' method that Ifixit recommends by charging to 100% for about 2 hours and then discharging completely.
I have attached the data of the jumps below recorded with HWiNFO. I also noticed the wear percentage increasing by about 2-3% every charge cycle.
Charging Jump
Discharge jump
PC: Alienware 15 R3  Cpu: 7700hq  GPu : 1070 OC   Display: 1080p IPS Gsync panel 60hz  Storage: 970 evo 250 gb / 970 evo plus 500gb
Audio: Sennheiser HD 6xx  DAC: Schiit Modi 3E Amp: Schiit Magni Heresy
https://linustechtips.com/topic/1610620-strange-battery-behaviour/
Thanks will try to do an RMA with IFixit !
