I have upgraded to a 5080 ROG Astral, which has a 12-pin power connector. For it to get sufficient power, I have used the adapter they provided (see image)
Currently I have 3 PCIe cables running into this. The cables plus the adapter looks really ugly since the adapters short so I've had to connect the cables in the front of the case. Are there any solutions I can buy to make it look better? Maybe longer adapters which can all be connected in the back of the case rather than showing all the junk in the front? Also I'm worried about compatibility with my parts as I've heard before that if you use different cables from your power supply or whatever it can cause issues.
https://linustechtips.com/topic/1610572-need-gpu-cable-advice/
