ITX Help
Go to solution Solved by Tetras,
Phanteks P200A can fit long(ish) ATX PSUs and a 240mm radiator.
11 minutes ago, mariushm said:
Why would you need a 1300 watts power supply in an ITX case?  Do you realize you can't actually dissipate the heat produced by video cards or processors that need 1300 watts in such a small case?
I would hope that they are just changing their system to ITX form and re-using the power supply, otherwise yes this is a little silly
Console.WriteLine("Hello World!");
https://linustechtips.com/topic/1610407-itx-help/#findComment-16716011
15 minutes ago, Wascie said:
I am looking for an ITX Case
Really struggling to find something that is not SFF.
Little confused about what you're looking for. ITX is a motherboard size standard, not a case standard. SFF is kind of an idea, also not really a standard.
What exactly are you looking for? Just a case that can fit that PSU and also accept an ITX motherboard?
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1610407-itx-help/#findComment-16716015
42 minutes ago, Wascie said:
I am looking for an ITX Case that can support an Antec Signature Platinum 1300w power supply which is approx 170mm long with 240mm rad support.
A bit confused by the requirements. If you don't want an SFF case why not use an M-ATX or ATX case. IOW, what are you trying to achieve?
https://linustechtips.com/topic/1610407-itx-help/#findComment-16716040
The answer to this is micro ATX, even if you have a mITX motherboard.
Look at the Asus AP201. Its a fully featured 'SFF' case that supports micro ATX boards and doesn't compromise on any hardware compatibility.
ASUS Prime AP201 MicroATX Case - Tech Specs|Gaming Case|ASUS USA
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
https://linustechtips.com/topic/1610407-itx-help/#findComment-16716051
Thanks Tetras for the Phanteks recommendation, this is perfect for my requirements.
As regards to why I wanted to use my Power Supply is because I want to downsize without adding to landfill, Phanteks clearly saw a need for my use case and made a case for it.
https://linustechtips.com/topic/1610407-itx-help/#findComment-16716896
