Midrange PC Upgrade Help
2 hours ago, 6amhotdog said:Yes, not too far, about 40 mins
Id recommend either of these depending on what you want to do
https://www.microcenter.com/product/5006990/amd-ryzen-5-7600x,-asus-b650m-a-prime-ax-ii,-gskill-flare-16gb-ddr5-6000,-computer-build-bundle
id look at this microcenter bundle and whatever 3060/4060/6600/7600 you can afford left over
to be honest this will play everything today good at 1080p 144hz and itll leave you on a modern platform but itll need a upgrade relatively (1yr or so) soon
IF you're willing to save now or just accept youll have to spend more later I would reccomend either this ryzen 7 7700x combo https://www.microcenter.com/product/5006968/amd-ryzen-7-7700x,-gigabyte-b650-gaming-x-ax-v2,-gskill-flare-x5-series-32gb-ddr5-6000-kit,-computer-build-bundle or the 7800x3d bundle someone else commented today and then saving for a RX 9060/9070 or a RTX 5060ti 16gb or RTX 5070 all of which will at a minimum run you about $400
doing the 7700x and 5060ti avaliable today at my local microcenter will run you about $850 so waaay over budget but this will keep you solid for years
